Lead vs. Lead Free Solder
Wearable electronics: boards, conductive materials, and projects from Adafruit!
sumanchaudhuri
Post by sumanchaudhuri »
I've been tinkering with some of the wearable projects on the adafruit learning website, specifically the LED hat project that reacts to sound. I purchased a lead-free solder for the project since the 60/40 lead solder was out of stock. I'm finding it very hard for the neopixels to stay connected to each other with the flex wiring. Move them a little and the wires come loose and I have to solder them again and again. I'm wondering if it's my poor soldering skills (I'm new to this, but watched a lot of youtube videos before I got started), or if it's because I'm using lead free solder. I read somewhere that beginners should use lead based solder...is it because it holds metal together better?
Any advice will be helpful.
Re: Lead vs. Lead Free Solder
Lead-free solder is a little trickier to work with. It helps to have a good temperature controlled soldering iron. If your joints are falling apart, the are probably 'cold' joints. You need to run the iron a bit hotter - usually around 725-750F (385-400C) compared to regular lead/tin solder. And make sure that the solder has flowed well onto both the wire and the solder-pad.
http://learn.adafruit.com/adafruit-guid ... -soldering
sumanchaudhuri
Thanks. So is it true that lead based solders "hold better" than lead free for the projects on your website?
Lead free solder will hold just as well when done right. But it takes a little more practice to learn how to make good joints with it.
Here is some more information about the differences between lead & lead-free soldering:
http://www.kester.com/kester-content/up ... .19.06.pdf
http://www.hakko.com/english/lead_free/pages/
Return to “Wearables”
