Flora and ffft library. Is it possible?
by essenciya on Tue Jul 30, 2013 12:47 am
Hi there,
I'm trying to build a wearable project based on Flora, very like http://learn.adafruit.com/piccolo/overview, in fact I want to use the same ffft lib, but instead of driving a matrix, I want to drive led those http://www.adafruit.com/products/1376 leds.
The problem I have is, the code for poccolo project (https://github.com/adafruit/piccolo) is using A0 pin for getting ADC output (I'm sorry if my terminology is incorrect). I wasn't able to find A0 input pin on Flora, but the microcontroller MEGA32U4 suppose to have one. Basically I stuck on where I should connect microphone on Flora to make ffft lib to work? And is it even possible with Flora? I assume breaking raw mic input into frequencies programmatically is a pretty heavy operation, maybe it's too much to ask from flora?
P.S. Guys I really appreciate the fact you have so many tutorials and crazy projects we can bounce of
essenciya
Re: Flora and ffft library. Is it possible?
by pburgess on Tue Jul 30, 2013 1:51 am
Hey there,
It's a little tricky, but I think it's doable. There are three analog-capable pins on the Flora: D6, D9 and D10 (corresponding to ADC channels 7, 9 and 10), according to pighixxx's diagram of awesomeness.
So, first choose which of those pins best suits your wiring, then we need to make some tweaks to the Piccolo code (or whatever code you derive from it). Here's the ADC setup code:
  ADMUX  = ADC_CHANNEL; // Channel sel, right-adj, use AREF pin
  ADCSRA = _BV(ADEN)  | // ADC enable
           _BV(ADSC)  | // ADC start
           _BV(ADATE) | // Auto trigger
           _BV(ADIE)  | // Interrupt enable
           _BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0); // 128:1 / 13 = 9615 Hz
  ADCSRB = 0;                // Free run mode, no high MUX bit
  DIDR0  = 1 << ADC_CHANNEL; // Turn off digital input for ADC pin
  TIMSK0 = 0;                // Timer0 off
Delete the ADMUX and DIDR0 lines, then append this extra block of code:
#if (ADC_CHANNEL > 7)
  ADMUX  = B00100000 | (ADC_CHANNEL - 8);
  DIDR2  = 1 << (ADC_CHANNEL - 8);
#else
#endif
Remember, ADC_CHANNEL must be 7, 9 or 10 on the Flora, and the channel number does not always directly correspond to the pin number.
I've not actually tested this code, just scrounged around in the datasheet. I think it'll work, but let me know if you run into any trouble.
pburgess
by essenciya on Tue Jul 30, 2013 7:16 am
Hey pburgess,
Thanks for quick response, I'm looking on the http://forum.arduino.cc/index.php?topic=179657.0 and it confuses me a bit. What you saying is mic should sit on pin D6,D9 or D10 (corresponding to A7, A9 and A10), but ADC on the diagram marked as ADC10, ADC12 and ADC13 respectively. So let's say for my wiring I decided to put mic on D10/A10/ADC13. What would be a value of the ADC_CHANNEL? 10 or 13?
Let me tell what I tried and how it "didn't work" :)
Given pure piccolo code, I removed all matrix references and following libs Adafruit_GFX.h, Adafruit_LEDBackpack.h My setup looks like:
#define ADC_CHANNEL 10 //Microphone is connected to D10 pin of the Flora
  uint8_t i, j, nBins, binNum, *data;
  memset(peak, 0, sizeof(peak));
  memset(col , 0, sizeof(col));
  for(i=0; i<8; i++) {
    minLvlAvg[i] = 0;
    maxLvlAvg[i] = 512;
    data         = (uint8_t *)pgm_read_word(&colData[i]);
    nBins        = pgm_read_byte(&data[0]) + 2;
    binNum       = pgm_read_byte(&data[1]);
    for(colDiv[i]=0, j=2; j<nBins; j++)
      colDiv[i] += pgm_read_byte(&data[j]);
  #else
  #endif
  sei(); // Enable interrupts
  Serial.begin(9600);//For Debugging
In a loop I'm printing to serial out directly after calculation for the current column is done:
 // Clip output and convert to byte:
 if(level < 0L)      c = 0;
    else if(level > 10) c = 10; // Allow dot to go a couple pixels off top
    else                c = (uint8_t)level;
    Serial.print("column:");
    Serial.print(x);
    Serial.print(" level ");
    Serial.println(c);
What I see in serial out:
column:0 level 4
column:1 level 4
column:2 level 0
column:3 level 0
column:4 level 0
column:5 level 0
column:6 level 0
column:7 level 0
column:0 level 4
column:1 level 4
column:2 level 0
column:3 level 0
column:4 level 0
column:5 level 0
column:6 level 0
column:7 level 0
And so on, without any changes in numbers despite noise or quietness.
I feel, like it should be some small thing, but i keep overlooking it. Can you spot what can be wrong? Nothing else was changed in original piccolo code or ffft lib. Nothing else is connected to Flora (just a mic).
Highly appreciate any lead on this,
Max
essenciya
by pburgess on Tue Jul 30, 2013 2:45 pm
Blargh, you're right...it was late when I wrote that...A7, A9 and A10 are the analog pin numbers, but 10, 12 and 13 are the actual channel numbers. So yes, use the latter numbers. Pin D6 = ADC channel 10, D9 = channel 12, D10 = 13.
pburgess
by essenciya on Wed Jul 31, 2013 4:05 am
Unfortunately setting channel to 13 didn't change much. Similar output as in my previous post, but numbers for first and second column changed to 4 and 3. What is weird why other always zeros? May it be that from 128 frequencies ffft lib outputs piccolo project chosen least interesting?
essenciya
by pburgess on Thu Aug 01, 2013 1:26 pm
I think the smattering of 4s & 3s are just an artifact of how the ffft library works...very limited resolution fixed-point math stuff. What's baffling right now is why isn't it reading the mic? Could you post your complete sketch?
pburgess
by essenciya on Fri Aug 02, 2013 8:27 am
I run out of ideas, I hope you can see what's wrong with the sketch:
#include <avr/pgmspace.h>
#include <ffft.h>
#include <math.h>
#include <Wire.h>
int16_t       capture[FFT_N];    // Audio capture buffer
complex_t     bfly_buff[FFT_N];  // FFT "butterfly" buffer
uint16_t      spectrum[FFT_N/2]; // Spectrum output buffer
volatile byte samplePos = 0;     // Buffer position counter
byte
  peak[8],      // Peak level of each column; used for falling dots
  dotCount = 0, // Frame counter for delaying dot-falling speed
  colCount = 0; // Frame counter for storing past column data
int
  col[8][10],   // Column levels for the prior 10 frames
  minLvlAvg[8], // For dynamic adjustment of low & high ends of graph,
  maxLvlAvg[8], // pseudo rolling averages for the prior few frames.
  colDiv[8];    // Used when filtering FFT output to 8 columns
PROGMEM uint8_t
  // This is low-level noise that's subtracted from each FFT output column:
  noise[64]={ 8,6,6,5,3,4,4,4,3,4,4,3,2,3,3,4,
              2,1,2,1,3,2,3,2,1,2,3,1,2,3,4,4,
              3,2,2,2,2,2,2,1,3,2,2,2,2,2,2,2,
              2,2,2,2,2,2,2,2,2,2,2,2,2,3,3,4 },
  // These are scaling quotients for each FFT output column, sort of a
  // graphic EQ in reverse.  Most music is pretty heavy at the bass end.
  eq[64]={
    255, 175,218,225,220,198,147, 99, 68, 47, 33, 22, 14,  8,  4,  2,
      0,   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
      0,   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0 },
  col0data[] = {  2,  1,  // # of spectrum bins to merge, index of first
    111,   8 },           // Weights for each bin
  col1data[] = {  4,  1,  // 4 bins, starting at index 1
     19, 185,  38,   2 }, // Weights for 4 bins.  Got it now?
  col2data[] = {  5,  2,
     11, 156, 118,  16,   1 },
  col3data[] = {  8,  3,
      5,  55, 165, 164,  71,  18,   4,   1 },
  col4data[] = { 11,  5,
      3,  24,  89, 169, 178, 118,  54,  20,   6,   2,   1 },
  col5data[] = { 17,  7,
      2,   9,  29,  70, 125, 172, 185, 162, 118, 74,
     41,  21,  10,   5,   2,   1,   1 },
  col6data[] = { 25, 11,
      1,   4,  11,  25,  49,  83, 121, 156, 180, 185,
    174, 149, 118,  87,  60,  40,  25,  16,  10,   6,
      4,   2,   1,   1,   1 },
  col7data[] = { 37, 16,
      1,   2,   5,  10,  18,  30,  46,  67,  92, 118,
    143, 164, 179, 185, 184, 174, 158, 139, 118,  97,
     77,  60,  45,  34,  25,  18,  13,   9,   7,   5,
      3,   2,   2,   1,   1,   1,   1 },
  // And then this points to the start of the data for each of the columns:
  *colData[] = {
    col0data, col1data, col2data, col3data,
    col4data, col5data, col6data, col7data };
#define N_PIXELS  15  // Number of pixels in strand
#define LED_PIN_INNER    12  // NeoPixel LED strand is connected to this pin
#define LED_PIN_MIDLE    6  // NeoPixel LED strand is connected to this pin
#define LED_PIN_OUTER    9  // NeoPixel LED strand is connected to this pin
#define ADC_CHANNEL 13 //Microphone is connected to this pin
//Adafruit_NeoPixel  strip_inner = Adafruit_NeoPixel(N_PIXELS, LED_PIN_INNER, NEO_GRB + NEO_KHZ800);
//Adafruit_NeoPixel  strip_midle = Adafruit_NeoPixel(N_PIXELS, LED_PIN_MIDLE, NEO_GRB + NEO_KHZ800);
//Adafruit_NeoPixel  strip_outer = Adafruit_NeoPixel(N_PIXELS, LED_PIN_OUTER, NEO_GRB + NEO_KHZ800);
    minLvlAvg[i] = 0;
    maxLvlAvg[i] = 512;
//  strip_inner.begin();
//  strip_midle.begin();
//  strip_outer.begin();
  // Init ADC free-run mode; f = ( 16MHz/prescaler ) / 13 cycles/conversion
  #else
  #endif
  uint8_t  i, x, L, *data, nBins, binNum, weighting, c;
  uint16_t minLvl, maxLvl;
  int      level, y, sum;
  while(ADCSRA & _BV(ADIE)); // Wait for audio sampling to finish
  fft_input(capture, bfly_buff);   // Samples -> complex #s
  samplePos = 0;                   // Reset sample counter
  ADCSRA |= _BV(ADIE);             // Resume sampling interrupt
  fft_execute(bfly_buff);          // Process complex data
  fft_output(bfly_buff, spectrum); // Complex -> spectrum
  // Remove noise and apply EQ levels
  for(x=0; x<FFT_N/2; x++) {
    L = pgm_read_byte(&noise[x]);
    spectrum[x] = (spectrum[x] <= L) ? 0 :
      (((spectrum[x] - L) * (256L - pgm_read_byte(&eq[x]))) >> 8);
  // Downsample spectrum output to 8 columns:
  for(x=0; x<8; x++) {
    data   = (uint8_t *)pgm_read_word(&colData[x]);
    for(sum=0, i=2; i<nBins; i++)
      sum += spectrum[binNum++] * pgm_read_byte(&data[i]); // Weighted
    col[x][colCount] = sum / colDiv[x];                    // Average
    minLvl = maxLvl = col[x][0];
    for(i=1; i<10; i++) { // Get range of prior 10 frames
      if(col[x][i] < minLvl)      minLvl = col[x][i];
      else if(col[x][i] > maxLvl) maxLvl = col[x][i];
    if((maxLvl - minLvl) < 8) maxLvl = minLvl + 8;
    minLvlAvg[x] = (minLvlAvg[x] * 7 + minLvl) >> 3; // Dampen min/max levels
    maxLvlAvg[x] = (maxLvlAvg[x] * 7 + maxLvl) >> 3; // (fake rolling average)
    // Second fixed-point scale based on dynamic min/max levels:
    level = 10L * (col[x][colCount] - minLvlAvg[x]) /
      (long)(maxLvlAvg[x] - minLvlAvg[x]);
    Serial.print(x);
    Serial.println(c);
    if(c > peak[x]) peak[x] = c; // Keep dot on top
    if(peak[x] <= 0) { // Empty column?
      //Clean the strip here
      continue;
    } else if(c < 8) { // Partial column?
      //Clean part of the strip here
    y = N_PIXELS - peak[x];
    //Draw strips here!!!
//   strip_inner.show();
//   strip_midle.show();
//   strip_outer.show();
  // Every third frame, make the peak pixels drop by 1:
  if(++dotCount >= 3) {
    dotCount = 0;
      if(peak[x] > 0) peak[x]--;
  if(++colCount >= 10) colCount = 0;
ISR(ADC_vect) { // Audio-sampling interrupt
  static const int16_t noiseThreshold = 4;
  int16_t              sample         = ADC; // 0-1023
  capture[samplePos] =
    ((sample > (512-noiseThreshold)) &&
     (sample < (512+noiseThreshold))) ? 0 :
    sample - 512; // Sign-convert for FFT; -512 to +511
  if(++samplePos >= FFT_N) ADCSRA &= ~_BV(ADIE); // Buffer full, interrupt off
Wiring is as follows: mic (http://www.adafruit.com/products/1063) connected to 3.3V, ground and D10, nothing else is connected at the moment. The reading is all zeros right now, and column 0 sometimes shows 10 (only 10 or 0, nothing in between, so I don't think mic reading affecting it, but rather ffft calcs)
Any advice is highly appreciated,
Max Ch
essenciya
by pburgess on Fri Aug 02, 2013 4:17 pm
Ah! I think I see what it is. There's no AREF pin on the Flora. One more small code change tells it to use VCC as a voltage reference:
  ADMUX  = _BV(REFS0) | _BV(MUX5) | (ADC_CHANNEL - 8);
#else
  ADMUX  = _BV(REFS0) | ADC_CHANNEL;
#endif
Computers will make our lives simpler! :D
pburgess
by essenciya on Mon Aug 05, 2013 5:25 am
Pburgess, huge personal thanks for your help. But it still didn't work. Seems like it just don't want to read from mic. On the weekend I put all wiring on, and run different code (based on http://learn.adafruit.com/led-ampli-tie/the-code) which also takes input from mic (analog read from pin though) and outputs to my leds. All worked as expected, so mic, power supply, led strips itself and soldering all should be good. Now when I run my code with ffft, it just stay dead on the same hardware. This leads me to conclusion it must be software problem. And it has to do with reading input bytes from ADC right? How can I debug this? I'm good in dynamic languages (basically I'm Java/Android developer) but having problems when it comes to interruptions and direct memory access type of stuff, if you can lead me to the right directions I can dig )
essenciya
by pburgess on Mon Aug 05, 2013 3:15 pm
Okay, one more pass through the datasheet, this time with the benefit of a good night's rest:
  ADMUX  = _BV(REFS0) | (ADC_CHANNEL - 8);
  ADCSRB = _BV(MUX5);        // Free run mode, high MUX bit
#else
#endif
Wired up and tested with a Flora. This should work for you, though you may need to edit the 'eq' table to bring out certain frequencies for whatever you're listening to.
pburgess
by essenciya on Mon Aug 05, 2013 7:40 pm
can you show your test sketch?
essenciya
by pburgess on Mon Aug 05, 2013 8:57 pm
It's the exact code you posted, with my latest ADMUX/ADCSRB/DIDR2 changes, with the mic connected to pin 10 (ADC channel 13).
pburgess
by essenciya on Mon Aug 12, 2013 5:36 am
Unfortunately I still couldn't get it to work. Buffer return always the same. But thanks for all help, maybe I'll return later to this and will find how to make it work, I'm done fighting it for now though.
essenciya
by pburgess on Mon Aug 12, 2013 11:46 pm
You might need to edit the 'eq' array to all zeros to start. Also, before you do that, whistle a range of different tones at it...it might just be that it's not responding to whatever pitch you were testing with.
pburgess
