I want to change the way the neopixels light up on my Tie.
I'm wanting all the neopixels in one color (red), and to get brighter as the sound increased to the microphone.
Example:
When no sound, no lit neopixels.
When little sound, all neopixels dimly lit in red color.
When max sound, all neopixels brightly lit in red color.
Can someone help me with writing the program?
LED Ampli-Tie
- adafruit_support_rick
Re: LED Ampli-Tie
See if this does what you want. Note: I haven't actually run this because I don't have all the parts here with me, but it ought to be close. You may have to play with it a bit.
LED VU meter for Arduino and Adafruit NeoPixel LEDs.
Hardware requirements:
- Most Arduino or Arduino-compatible boards (ATmega 328P or better).
- Adafruit Electret Microphone Amplifier (ID: 1063)
- Adafruit Flora RGB Smart Pixels (ID: 1260)
OR
- Adafruit NeoPixel Digital LED strip (ID: 1138)
- Optional: battery for portable use (else power through USB or adapter)
Software requirements:
- Adafruit NeoPixel library
Connections:
- 3.3V to mic amp +
- GND to mic amp -
- Analog pin to microphone output (configurable below)
- Digital pin to LED data input (configurable below)
See notes in setup() regarding 5V vs. 3.3V boards - there may be an
extra connection to make and one line of code to enable or disable.
Written by Adafruit Industries. Distributed under the BSD license.
This paragraph must be included in any redistribution.
#define N_PIXELS 16 // Number of pixels in strand
#define MIC_PIN A9 // Microphone is attached to this analog pin
#define LED_PIN 6 // NeoPixel LED strand is connected to this pin
#define DC_OFFSET 0 // DC offset in mic signal - if unusure, leave 0
#define NOISE 10 // Noise/hum/interference in mic signal
#define SAMPLES 60 // Length of buffer for dynamic level adjustment
#define TOP (N_PIXELS + 2) // Allow dot to go slightly off scale
#define PEAK_FALL 40 // Rate of peak falling dot
byte
peak = 0, // Used for falling dot
dotCount = 0, // Frame counter for delaying dot-falling speed
volCount = 0; // Frame counter for storing past volume data
int
vol[SAMPLES], // Collection of prior volume samples
lvl = 10, // Current "dampened" audio level
minLvlAvg = 0, // For dynamic adjustment of graph low & high
maxLvlAvg = 512;
Adafruit_NeoPixel
strip = Adafruit_NeoPixel(N_PIXELS, LED_PIN, NEO_GRB + NEO_KHZ800);
// This is only needed on 5V Arduinos (Uno, Leonardo, etc.).
// Connect 3.3V to mic AND TO AREF ON ARDUINO and enable this
// line. Audio samples are 'cleaner' at 3.3V.
// COMMENT OUT THIS LINE FOR 3.3V ARDUINOS (FLORA, ETC.):
// analogReference(EXTERNAL);
memset(vol, 0, sizeof(vol));
strip.begin();
for (int i = 0; i < N_PIXELS; i++)
strip.setPixelColor(i, 255, 0, 0); //set all pixels to red
strip.setBrightness(0); //turn all pixels off
strip.show(); //update strip
uint8_t i;
uint16_t minLvl, maxLvl;
int n, bright;
n = analogRead(MIC_PIN); // Raw reading from mic
n = abs(n - 512 - DC_OFFSET); // Center on zero
n = (n <= NOISE) ? 0 : (n - NOISE); // Remove noise/hum
lvl = ((lvl * 7) + n) >> 3; // "Dampened" reading (else looks twitchy)
// Calculate brightness based on dynamic min/max levels (fixed point):
bright = TOP * (lvl - minLvlAvg) / (long)(maxLvlAvg - minLvlAvg);
if(bright < 0L) bright = 0; // Clip output
else if(bright > TOP) bright = TOP;
if(bright > peak) peak = bright; // Keep 'peak' dot at top
strip.setBrightness(bright);
strip.show(); // Update strip
vol[volCount] = n; // Save sample for dynamic leveling
if(++volCount >= SAMPLES) volCount = 0; // Advance/rollover sample counter
// Get volume range of prior frames
minLvl = maxLvl = vol[0];
for(i=1; i<SAMPLES; i++) {
if(vol[i] < minLvl) minLvl = vol[i];
else if(vol[i] > maxLvl) maxLvl = vol[i];
// minLvl and maxLvl indicate the volume range over prior frames, used
// for vertically scaling the output graph (so it looks interesting
// regardless of volume level). If they're too close together though
// (e.g. at very low volume levels) the graph becomes super coarse
// and 'jumpy'...so keep some minimum distance between them (this
// also lets the graph go to zero when no sound is playing):
if((maxLvl - minLvl) < TOP) maxLvl = minLvl + TOP;
minLvlAvg = (minLvlAvg * 63 + minLvl) >> 6; // Dampen min/max levels
maxLvlAvg = (maxLvlAvg * 63 + maxLvl) >> 6; // (fake rolling average)
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
- superprojb
Re: LED Ampli-Tie
Thank you for the quick reply. After installing the code, none of the neopixels light up, regardless of the level sound input at the microphone.
I tried changing a few values, but I'm not seeing my issue to get some neopixels to light up. I did reload the Ampli-tie code and it works, but switching back to new code, nothing is lighting up.
Any ideas or suggestion are welcomed. Thank you in advance.
Re: LED Ampli-Tie
Sorry - my mistake. I forgot how setBrightness worked...
Try this:
Try this:
OR
Connections:
- 3.3V to mic amp +
- GND to mic amp -
byte
int
maxLvlAvg = 512;
Adafruit_NeoPixel
strip.begin();
strip.setPixelColor(i, 0, 0, 0); //turn off all pixels
uint8_t i;
int n, bright;
if(WheelPos < 85) {
WheelPos -= 85;
} else {
WheelPos -= 170;
- superprojb
Re: LED Ampli-Tie
AWESOME!!! It works!! =)
- superprojb
Re: LED Ampli-Tie
Rick, thank you again!
I have one last configuration to ask for your help Ok, this one works like the Ampli-tie, but all colors are red, and the max Neopixel is white.
So, instead of the multi-colors, only a red color for all Neopixels, but the max Neopixel to be white. Dont change the action, but only the colors to red and white?
I will be making 2 each of the different (3 styles) Ampli-ties for Graduation. Thank you in advance and thank you Adafruit! =)
Re: LED Ampli-Tie
OR
Connections:
- 3.3V to mic amp +
- GND to mic amp -
byte
int
maxLvlAvg = 512;
Adafruit_NeoPixel
strip.begin();
uint8_t i;
int n, height;
// Calculate bar height based on dynamic min/max levels (fixed point):
height = TOP * (lvl - minLvlAvg) / (long)(maxLvlAvg - minLvlAvg);
if(height < 0L) height = 0; // Clip output
else if(height > TOP) height = TOP;
if(height > peak) peak = height; // Keep 'peak' dot at top
// Color pixels based on rainbow gradient
for(i=0; i<N_PIXELS; i++) {
if(i >= height) strip.setPixelColor(i, 0, 0, 0);
else strip.setPixelColor(i, 255, 0, 0);
// Draw peak dot
if(peak > 0 && peak <= N_PIXELS-1) strip.setPixelColor(peak, 255, 255, 255);
// Every few frames, make the peak pixel drop by 1:
if(++dotCount >= PEAK_FALL) { //fall rate
if(peak > 0) peak--;
dotCount = 0;
if(WheelPos < 85) {
WheelPos -= 85;
} else {
WheelPos -= 170;
- superprojb
Re: LED Ampli-Tie
Rick, you may not hear it enough, but I want to thank you for your prompt, professional, and expert help in my Adafruit service form topic. You have provided great customer service/support that exceeded my expiations.
I believe a company that sells its own products is only as good as its customer service/support. It’s the support after the sale that keeps the customers satisfied and helps grow your future sales.
I am 100% satisfied with Adafruit’s product design/production, quality control, sales, shipping, and your service/support Rick.
I will be a customer for life! Thank you Rick and Adafruit.
Re: LED Ampli-Tie
You're welcome!
- superprojb
Re: LED Ampli-Tie
I need to power up a 2nd strand of neo pixels to have the same program, but with a green color.
Is it possible to modify this Flora program to have a 2nd output for the 2nd strand of green neo pixels? (same progam for the red, but with a green color & on a different output pin)
So... I need the Flora to output #6 pin for the red strand of neo pixels, and output #12 pin output for the green strand of neo pixels.
OR
Connections:
- 3.3V to mic amp +
- GND to mic amp -
byte
int
maxLvlAvg = 512;
Adafruit_NeoPixel
strip.begin();
uint8_t i;
int n, bright;
if(WheelPos < 85) {
WheelPos -= 85;
} else {
WheelPos -= 170;
Last edited by adafruit_support_rick on Sun May 04, 2014 3:07 pm, edited 1 time in total.
Reason: please use Code tags when posting code (</> button)
Re: LED Ampli-Tie
Declare two NeoPixel objects:
Wherever you have "strip", change it to "stripRed". Then add another identical line, but for "stripGreen"
#define N_RED_PIXELS 16 // Number of pixels in strand
#define RED_PIN 6 // Red NeoPixel LED strand is connected to this pin
#define N_GREEN_PIXELS 16 // Number of pixels in strand
#define GREEN_PIN 12 // Green NeoPixel LED strand is connected to this pin
Adafruit_NeoPixel stripRed = Adafruit_NeoPixel(N_RED_PIXELS, RED_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripGreen= Adafruit_NeoPixel(N_GREEN_PIXELS, GREEN_PIN, NEO_GRB + NEO_KHZ800);
- superprojb
Re: LED Ampli-Tie
I have tried to make all the changes, but I keep getting a error when I start to upload.
'stripRed' not declared in this scope
Can someone help correct the issue?
OR
Connections:
- 3.3V to mic amp +
- GND to mic amp -
#define N_RED_PIXELS 16 // Number of RED pixels in strand
#define N_GREEN_PIXELS 16 // Number of GREEN pixels in strand
#define RED_PIN 6 // NeoPixel RED strand is connected to this pin
#define GREEN_PIN 12 // NeoPixel GREEN strand is connected to this pin
#define DC_OFFSET 10 // DC offset in mic signal - if unusure, leave 0
#define NOISE 24 // Noise/hum/interference in mic signal
byte
int
lvl = 1, // Current "dampened" audio level
maxLvlAvg = 512;
Adafruit_NeoPixel stripGREEN = Adafruit_NeoPixel(N_GREEN_PIXELS, GREEN_PIN, NEO_GRB + NEO_KHZ800);
stripRED.begin();
stripGREEN.begin();
uint8_t i;
int n, height;
lvl = ((lvl * 6) + n) >> 3; // "Dampened" reading (else looks twitchy)
if(i >= height) stripRED.setPixelColor(i, 0, 0, 0) stripGREEN.setPixelColor(i, 0, 0, 0);
else stripRED.setPixelColor(i, 255, 0, 0) stripGREEN.setPixelColor(i, 255, 0, 0);
// Draw peak dot
if(peak > 0 && peak <= N_PIXELS-1) stripRED.setPixelColor(peak, 255, 255, 255) stripGREEN.setPixelColor(peak, 255, 255, 255);
stripRED.show() stripGREEN.show(); // Update strip
dotCount = 0;
if(WheelPos < 85) {
return stripRED.Color(WheelPos * 3, 255 - WheelPos * 3, 0) stripGREEN.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
WheelPos -= 85;
return stripRED.Color(255 - WheelPos * 3, 0, WheelPos * 3) stripGREEN.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return stripRED.Color(0, WheelPos * 3, 255 - WheelPos * 3) stripGREEN.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Re: LED Ampli-Tie
You are referring to "stripRED" in the code:
But you're declared it as "stripRed"
Capitalization counts.
stripRED.begin();
- superprojb
Re: LED Ampli-Tie
My mistake. I made the correction, now there is another error.
N_PIXELS was not declared
- Attachments
- Adafruit_1.jpg (48.29 KiB) Viewed 275 times
