i built a pair of firewalker sneakers. But the only color they show is green.
I used the standart programming code from adafruit website and sadly iam not into the programming stuff enough to make my sneakers glow blizzardwalker blue.
Im going to the worlds biggest house festival Tomorrowland on thursday, where id like to wear them.
Could someone help me out?
thank you.
Best regards,
Kris from germany
Firewalker ColorCodes Blizzardwalker
- adafruit_support_rick
Re: Firewalker ColorCodes Blizzardwalker
Actually, I don't see how it's possible to get pure green - the code isn't written that way. Have you modified the code at all?
Where did you get the NeoPixels, from us?
Which NeoPixel strip did you buy?
hi,
i asked your supplier in germany for help. he didnt answer. so i bought the floras from his shop. the rest i bought from germany, switzerland, england and the LED Stripes from China. They are able to show every colour. I saw that, when i had some cables touching contacts incorrectly.
Last edited by Blizzardwalker on Fri Jul 18, 2014 5:23 pm, edited 1 time in total.
i already thought, that my LED Stripes will response in a different way to your codes. - Just because they are from china. So then i thought, when the actual code (for firewalkers) show green on my stripes, i could type in different numbers into the colourcode so (thougth around that corner) it will somehow show blue.
I only changed numbers of LEDs for my shoesize. It all works fine. Even my testcircuit was green also.
Try changing the strip declaration from NEO_GRB to NEO_RGB:
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LED_PIN, NEO_RGB + NEO_KHZ800);
thank you for your help.
Now with that code they are glowing purely red.
Does that make me come closer to have blue walkers? :-)
