I am building a pair of the firewalker shoes. Everything seems to be working fine except for the velostat step sensors. When no pressure is being applied, the values range from 0 to ~800 and is very noisy. When pressure is applied, the values are just as noisy but the range is a bit smaller. I can see from the firewalker code that "the readings from the sensors are usually around 250-350 when not being pressed, then dip below 100 when the heel is standing on it". This is not the case for my sensors. We fashioned the sensors as was shown on the firewalker tutorial. What else could be the problem? Thanks!
Firewalker Shoes - Velostat Sensor Too Sensitive and Noisy
- daprat
- adafruit_support_bill
Re: Firewalker Shoes - Velostat Sensor Too Sensitive and Noi
Post a photo of your sensors. Make sure that the two pieces of conductive thread are routed so that they do not accidentally contact each other directly.
- daprat
The sensors are still acting the same way..very noisy. However, I fixed this by averaging an array of 25 sensor values and then using that as the overall "pressure" value. I had to tweak a few of the values to get it working with the firewalker code but I got it working well. HOWEVER, after working great for about 3-4 minutes, out of nowhere the values start fluctuating rapidly between ~-1000 and +1000. The LED strip also begins to light up randomly (random pixels and seemingly random colors). Not sure what is causing this. Attached is a picture of the front and back of the sensors (no wires are crossing) and the code I am using. I cannot figure out what is going on here. Any help would be much appreciated!
// 'Firewalker' LED sneakers sketch for Adafruit NeoPixels by Phillip Burgess
uint8_t gamma[] PROGMEM = { // Gamma correction table for LED brightness
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
// LEDs go around the full perimeter of the shoe sole, but the step animation
// is mirrored on both the inside and outside faces, while the strip doesn't
// necessarily start and end at the heel or toe. These constants help configure
// the strip and shoe sizes, and the positions of the front- and rear-most LEDs.
// Becky's shoes: 39 LEDs total, 20 LEDs long, LED #5 at back.
// Phil's shoes: 43 LEDs total, 22 LEDs long, LED #6 at back.
#define N_LEDS 45 // TOTAL number of LEDs in strip
#define SHOE_LEN_LEDS 20 // Number of LEDs down ONE SIDE of shoe
#define SHOE_LED_BACK 5 // Index of REAR-MOST LED on shoe
#define STEP_PIN 1 // Analog input for footstep
#define LED_PIN 7 // NeoPixel strip is connected here
#define MAXSTEPS 3 // Process (up to) this many concurrent steps
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
// The readings from the sensors are usually around 250-350 when not being pressed,
// then dip below 100 when the heel is standing on it (for Phil's shoes; Becky's
// don't dip quite as low because she's smaller).
#define STEP_TRIGGER 70 // Reading must be below this to trigger step
#define STEP_HYSTERESIS 150 // After trigger, must return to this level
int
stepMag[MAXSTEPS], // Magnitude of steps
stepX[MAXSTEPS], // Position of 'step wave' along strip
mag[SHOE_LEN_LEDS], // Brightness buffer (one side of shoe)
stepFiltered, // Current filtered pressure reading
stepCount, // Number of 'frames' current step has lasted
stepMin; // Minimum reading during current step
uint8_t
stepNum = 0, // Current step number in stepMag/stepX tables
dup[SHOE_LEN_LEDS]; // Inside/outside copy indexes
boolean
stepping = false; // If set, step was triggered, waiting to release
int MAX_PRESSURE = 570;
int MAX_QUEUE_SIZE = 25;
int queue[25];
int head,tail;
int totalVal;
Serial.begin(9600);
pinMode(1, INPUT_PULLUP); // Set internal pullup resistor for sensor pin
// As previously mentioned, the step animation is mirrored on the inside and
// outside faces of the shoe. To avoid a bunch of math and offsets later, the
// 'dup' array indicates where each pixel on the outside face of the shoe should
// be copied on the inside. (255 = don't copy, as on front- or rear-most LEDs).
// Later, the colors for the outside face of the shoe are calculated and then get
// copied to the appropriate positions on the inside face.
memset(dup, 255, sizeof(dup));
int8_t a, b;
for(a=1 , b=SHOE_LED_BACK-1 ; b>=0 ;) dup[a++] = b--;
for(a=SHOE_LEN_LEDS-2, b=SHOE_LED_BACK+SHOE_LEN_LEDS; b<N_LEDS;) dup[a--] = b++;
// Clear step magnitude and position buffers
memset(stepMag, 0, sizeof(stepMag));
memset(stepX , 0, sizeof(stepX));
strip.begin();
stepFiltered = analogRead(STEP_PIN); // Initial input
uint8_t i, j;
int pinValue = analogRead(STEP_PIN);
if(isFull())
Dequeue();
Enqueue(pinValue);
int avg = Average();
Serial.println(MAX_PRESSURE - avg);
// Read analog input, with a little noise filtering
//stepFiltered = ((stepFiltered * 3) + analogRead(STEP_PIN)) >> 2;
stepFiltered = MAX_PRESSURE - avg;
// The strip doesn't simply display the current pressure reading. Instead,
// there's a bit of an animated flourish from heel to toe. This takes time,
// and during quick foot-tapping there could be multiple step animations
// 'in flight,' so a short list is kept.
if(stepping) { // If a step was previously triggered...
if(stepFiltered >= STEP_HYSTERESIS) { // Has step let up?
stepping = false; // Yep! Stop monitoring.
// Add new step to the step list (may be multiple in flight)
stepMag[stepNum] = (STEP_HYSTERESIS - stepMin) * 6; // Step intensity
stepX[stepNum] = -80; // Position starts behind heel, moves forward
if(++stepNum >= MAXSTEPS) stepNum = 0; // If many, overwrite oldest
} else if(stepFiltered < stepMin) stepMin = stepFiltered; // Track min val
} else if(stepFiltered < STEP_TRIGGER) { // No step yet; watch for trigger
stepping = true; // Got one!
stepMin = stepFiltered; // Note initial value
//Serial.println("STEP!!!");
// Render a 'brightness map' for all steps in flight. It's like
// a grayscale image; there's no color yet, just intensities.
int mx1, px1, px2, m;
memset(mag, 0, sizeof(mag)); // Clear magnitude buffer
for(i=0; i<MAXSTEPS; i++) { // For each step...
if(stepMag[i] <= 0) continue; // Skip if inactive
for(j=0; j<SHOE_LEN_LEDS; j++) { // For each LED...
// Each step has sort of a 'wave' that's part of the animation,
// moving from heel to toe. The wave position has sub-pixel
// resolution (4X), and is up to 80 units (20 pixels) long.
mx1 = (j << 2) - stepX[i]; // Position of LED along wave
if((mx1 <= 0) || (mx1 >= 80)) continue; // Out of range
if(mx1 > 64) { // Rising edge of wave; ramp up fast (4 px)
m = ((long)stepMag[i] * (long)(80 - mx1)) >> 4;
} else { // Falling edge of wave; fade slow (16 px)
m = ((long)stepMag[i] * (long)mx1) >> 6;
mag[j] += m; // Add magnitude to buffered sum
stepX[i]++; // Update position of step wave
if(stepX[i] >= (80 + (SHOE_LEN_LEDS << 2)))
stepMag[i] = 0; // Off end; disable step wave
else
stepMag[i] = ((long)stepMag[i] * 127L) >> 7; // Fade
// For a little visual interest, some 'sparkle' is added.
// The cumulative step magnitude is added to one pixel at random.
long sum = 0;
for(i=0; i<MAXSTEPS; i++) sum += stepMag[i];
if(sum > 0) {
i = random(SHOE_LEN_LEDS);
mag[i] += sum / 4;
// Now the grayscale magnitude buffer is remapped to color for the LEDs.
// The code below uses a blackbody palette, which fades from white to yellow
// to red to black. The goal here was specifically a "walking on fire"
// aesthetic, so the usual ostentatious rainbow of hues seen in most LED
// projects is purposefully skipped in favor of a more plain effect.
uint8_t r, g, b;
int level;
for(i=0; i<SHOE_LEN_LEDS; i++) { // For each LED on one side...
level = mag[i]; // Pixel magnitude (brightness)
if(level < 255) { // 0-254 = black to red-1
r = pgm_read_byte(&gamma[level]);
g = b = 0;
} else if(level < 510) { // 255-509 = red to yellow-1
r = 255;
g = pgm_read_byte(&gamma[level - 255]);
b = 0;
} else if(level < 765) { // 510-764 = yellow to white-1
r = g = 255;
b = pgm_read_byte(&gamma[level - 510]);
} else { // 765+ = white
r = g = b = 255;
// Set R/G/B color along outside of shoe
strip.setPixelColor(i+SHOE_LED_BACK, r, g, b);
// Pixels along inside are funny...
j = dup[i];
if(j < 255) strip.setPixelColor(j, r, g, b);
strip.show();
delayMicroseconds(1500);
DATA STRUCTURES
boolean Enqueue(int val){
if(isFull())
return false;
tail++;
queue[tail % MAX_QUEUE_SIZE] = val;
totalVal += val;
return true;
boolean Dequeue(){
int val;
if(isEmpty())
return -1;
else{
head++;
val = queue[head % MAX_QUEUE_SIZE];
totalVal -= val;
boolean isEmpty(){
return (head == tail);
boolean isFull(){
return ((tail - MAX_QUEUE_SIZE) == head);
int Average(){
return totalVal / MAX_QUEUE_SIZE;
- Attachments
- IMG_20140820_233842.jpg (191.44 KiB) Viewed 213 times
- IMG_20140820_233847.jpg (191.76 KiB) Viewed 213 times
Your sensor looks fine. The noise could be due to an intermittent connection to somewhere. Make sure that all your conductive thread knots are tight.
Not sure what might cause the random behavior after 3-4 minutes. It is possible you may be seeing a stack crash. The available SRAM on these processors it pretty tight. Your queue may be pushing it over the top.
You could modify your queue to keep a pseudo running average with minimal storage:
accumulator += newSample;
average = accumulator/sampleCount;
accumulator -= average;
