Connecting Flora to Fona
- benhp
Re: Connecting Flora to Fona
I am now able to get to this menu. Now to test a phone call
- Screen Shot 2015-02-26 at 12.36.30 PM.png (265.33 KiB) Viewed 362 times
- benhp
Success! I have successfully sent a text message with the device. Thank so much for helping me through this.
- adafruit_support_rick
You're welcome!
- benhp
Rick I have another question and it regards to the actual code it self. I am only interested in sending a text message, to a preprogrammed number. I am running into problems trying to set up the code to automatically send, so I do not need to be plugged into a computer, to then type the commands into the device. I was wondering if you could help me this one more time
case 's': {
// send an SMS!
char sendto[21], message[141];
flushSerial();
//Serial.print(F("Send to #"));
sendto = This is where i was placing my phone number;
Serial.println(sendto);
Serial.print(F("Type out one-line message (140 char): "));
readline(message, 140);
Serial.println(message);
if (!fona.sendSMS(sendto, message)) {
Serial.println(F("Failed"));
} else {
Serial.println(F("Sent!"));
break;
char sendto[] = "1234567890";
char message[] = "This is your message"
flushSerial();
} else {
break;
if (!fona.sendSMS("1234567890", "This is your message")) {
} else {
break;
- benhp
I am getting hung up on taking the device off the computer. I have a lsm9ds0 9-DOF sensor attached to my flora along with the fona device. I am trying to make the Sensor's accelerometer data once x axis hits -3000 or y axis hits -1800 to send a text message. I get the Fona to initialize but I don't get any data from the sensor.
It wont let me attatch my code because it says I have spam in the code of I M E I but I cant take those out or the code breaks.
Put spaces in the I M E I. I'll take the spaces out and try to run it.
- benhp
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LSM9DS0.h>
#include <Adafruit_Sensor.h> // not used in this demo but required!
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 6
// i2c
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0();
char replybuffer[255];
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
void setupSensor()
// 1.) Set the accelerometer range
lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
// 2.) Set the magnetometer sensitivity
// 3.) Setup the gyroscope
lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_245DPS);
//lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_500DPS);
//lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_2000DPS);
void setup()
while (!Serial); // flora & leonardo
// Try to initialise and warn if we couldn't detect the chip
Serial.begin(115200);
Serial.println(F("FONA basic test"));
Serial.println(F("Initializing....(May take 3 seconds)"));
// make it slow so its easy to read!
// fonaSS.begin(4800); // if you're using software serial
Serial1.begin(4800); // if you're using hardware serial
// See if the FONA is responding
if (! fona.begin(Serial1)) { // can also try fona.begin(Serial1)
//Serial.println(F("Couldn't find FONA"));
while (1);
Serial.println(F("FONA is OK"));
// Print SIM card i m e i number.
char i m e i[15] = {0}; // MUST use a 16 character buffer for i m e i!
uint8_t i m e iLen = fona.geti m e i(i m e i);
if (i m e iLen > 0) {
//Serial.print("SIM card I M E I: "); Serial.println(I M E I);
!lsm.begin();
void loop()
lsm.read();
Serial.print("Accel X: "); Serial.print((int)lsm.accelData.x); Serial.print(" ");
Serial.print("Accel Y: "); Serial.print((int)lsm.accelData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.accelData.z); Serial.print(" ");
Serial.print("Gyro X: "); Serial.print((int)lsm.gyroData.x); Serial.print(" ");
Serial.print("Gyro Y: "); Serial.print((int)lsm.gyroData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.gyroData.z); Serial.println(" ");
//Serial.print("Temp: "); Serial.print((int)lsm.temperature); Serial.println(" ");
delay(1400);
if( (int)lsm.accelData.x > -3000 || (int)lsm.accelData.y > -1800 ){
Serial.print("We are standing");
else {
Serial.print("We are falling");
// if (!fona.sendSMS("1234567890", "This is TEST")) {
// Serial.println(F("Failed"));
// } else {
// Serial.println(F("Sent!"));
I'm getting sensor data here. You must have your LSM9DS0 hooked up wrong.
- benhp
I get the sensor data when I run the Library example code. it should send the text message when that sensor reads anything less than -3000 but I do not get a message.
Mine isn't passing the test to do that. It keeps printing out "We are standing"
- benhp
I get the same message now. It looks like it still needs to go through the serial monitor for the Fona to initialize. Is that true?
I don't think so. I added this to your code, but I did nothing else:
/* Initialise the sensor */
if(!lsm.begin())
/* There was a problem detecting the LSM9DS0 ... check your connections */
Serial.print(F("Ooops, no LSM9DS0 detected ... Check your wiring or I2C ADDR!"));
while(1);
Serial.println(F("Found LSM9DS0 9DOF"));
/* Setup the sensor gain and integration time */
setupSensor();
- benhp
Awesome I got it to work! I successfully was able to get the text message. I have one last question, and that is How do I get the flora to initialize the Fona? So that I don't have to go to the Serial.Monitor and initializing it that way.
Not sure what initialization you're referring to? Once you call fona.begin, it's ready to go.
