I got a problem, once my Flora is powered(USB cable or Lipo battery), the D7 built-in led will be on(slightly blink), while I am sure I don't have "digitalWrite(7,HIGH);" in my sketch. In this case, the serial monitor doesn't work. Maybe you have any idea about this problem?
Thanks.
D7 is always on, Flora
- adafruit_support_rick
Re: D7 is always on, Flora
The LED will "pulse" when the bootloader is running. This will happen for 10 seconds when power is first applied, or when you press the reset button.
If the LED is simply *blinking*, then that is the default blink sketch that is loaded onto the Flora at the factory.
Have you managed to load your own sketch yet? Can you post that sketch? If there's an error in it, possibly, it's causing the Flora to reset.
- lanxingshuier
Hi
Thanks for your reply. While I do have already load my own sketch and the D7 keep blinking.
Can you help to check my sketch maybe? I have contacted a 9dof sensor from Adafruit and a multiplexer to Flora.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LSM9DS0.h>
#include <Adafruit_Sensor.h>
int s0 = 10;
int s1 = 9;
int s2 = 6;
int s3 =12;
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0();
void setupSensor()
// 1.) Set the accelerometer range
lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_4G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_6G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_8G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_16G);
// 2.) Set the magnetometer sensitivity
lsm.setupMag(lsm.LSM9DS0_MAGGAIN_2GAUSS);
//lsm.setupMag(lsm.LSM9DS0_MAGGAIN_4GAUSS);
//lsm.setupMag(lsm.LSM9DS0_MAGGAIN_8GAUSS);
//lsm.setupMag(lsm.LSM9DS0_MAGGAIN_12GAUSS);
// 3.) Setup the gyroscope
lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_245DPS);
//lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_500DPS);
//lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_2000DPS);
void setup()
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
Serial.begin(9600);
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
delay(200);
while (!Serial); // flora & leonardo
Serial.println("LSM raw read demo");
// Try to initialise and warn if we couldn't detect the chip
if (!lsm.begin())
Serial.println("Oops ... unable to initialize the LSM9DS0. Check your wiring!");
while (1);
delay(200);
void loop()
delay(200);
lsm.read();
Serial.print("Accel X: "); Serial.print((int)lsm.accelData.x); Serial.print(" ");
Serial.print("Y: "); Serial.print((int)lsm.accelData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.accelData.z); Serial.print(" ");
Serial.print("Mag X: "); Serial.print((int)lsm.magData.x); Serial.print(" ");
Serial.print("Y: "); Serial.print((int)lsm.magData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.magData.z); Serial.print(" ");
Serial.print("Gyro X: "); Serial.print((int)lsm.gyroData.x); Serial.print(" ");
Serial.print("Y: "); Serial.print((int)lsm.gyroData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.gyroData.z); Serial.println(" ");
Serial.print("Temp: "); Serial.print((int)lsm.temperature); Serial.println(" ");
delay(300);
What do you see in the serial monitor when you run that sketch?
- lanxingshuier
blank window, do you think D7 is blinking may because of the power is not stable on the Flora board?
- lanxingshuier
It seems like, I powered the Flora with cable or Lipo battery, 50% chance the D7 is blinking, when it's normal, the sketch will run correctly and I can read data from the Serial window.
It is possible you have a power problem or something else that is causing the Flora to reset. Try a different USB cable if you have one.
