Gemma FireWalker Shoes - How do I change the color scheme?
- TopHatRaver
I thought I saw a posting or video describing how to change the color scheme on the new Gemma version of the firewalker shoes but I cannot find it again. Currently they flow rainbow colors which is awesome but I'm considering putting a switch on them to allow the wearer to choose the rainbow or the red/orange/yellow fire color. I'm not even sure if there is enough memory space on the Gemma to do this, but worth a try.
- logan42
Re: Gemma FireWalker Shoes - How do I change the color schem
i know that there is a example in the neopixel library showing how to change patterns using a push button. you could try modifying that if nothing else.
- Mariejones13
If you don't mind, can you please help me with my firewalk sneakers I'm not sure how to connect my rgbw neopixel strip to Gemma board because the neopixel has a connector on it with a black and red wire
- TopHatRaver
I cut those wires off at the end of the strip and soldered my own silicon wires to the strip. This was better as the silicon wires are far more flexible and easier to work with when attaching/sewing them to the shoes. If you're adding the individual LED's to your strips, double check the connections/solder joints. I've had mine fail twice now. Good luck!
- TopHatRaver
I found the posting which shows how to change the color scheme on the original Flora FireWalker Shoes but that code is far different from the one used for the Gemma Lite version of the shoes and I don't believe that would work. I'm looking to make them more like the originals - which really look like Fire but I'm struggling to understand and modify the Gemma coding to accomplish this. Any help, guidance, suggestions would be greatly appreciated!
