Trinket bootloader problem
waluk99
Post by waluk99 »
Hey
I have a problem with the bootloader of my Trinket.
I tried to repair the bootloader with yout "trinketloader" sketch for arduino uno, but i got this error message:
"Reading signature:0
(no target attached?)
Signature fail"
I hope anyone can help me.
greeting from Germany!
adafruit_support_rick
Re: Trinket bootloader problem
Post by adafruit_support_rick »
Sounds like it may be a connection problem. Try a different USB cable or a different USB port
fidlerro
Post by fidlerro »
I am trying to do the same thing but my error message is different.
First, I am unable to get my Trinket 5V back into bootloader mode so my next thought was to reflash it so... here I am.
Serial Console:
Trinket loader!
Type 'G' or hit BUTTON for next chip
Starting Program Mode [OK}
Reading signature:FFFF
Searching for image...
Not Found
Image fail
Any help would be much appropriated, I've looked at the tutorial and noticed that it's looking for "blankfull.hex".
This file is NOT in the download from the tutorial so did I miss something?
Also noticed at the top of 'trinketloader.ino'
#include "optiLoader.h" <-- I have this file
#include "SPI.h" <-- I DON'T have this file
So i am not sure how the images.cpp is loaded "C newbie."
Thanks again,
Robert Fidler
Springfield, Missouri
You appear to be reading the an incorrect chip signature from the Trinket. Try using a different USB cable or a different USB port. What kind of computer are you using? Are you using a USB3.0 port?
fidlerro
Post by fidlerro »
i have a USB port that flakes out from time to time, I switched to one of the ports in the back of the PC and everything worked as expected.
Thanks again.
samy
Post by samy »
Hello, I appear to be having a similar issue using a MacBook Pro on OS X 10.8.5 and trying to repair the bootloader on a Gemma (the gemma does not start up in bootloader mode [no red light on at all, just the PWR light])
I tried both USB ports. First it was erroring like this:
Trinket loader!
Starting Program Mode [OK]
Reading signature:9302
Not Found
Image fail
Then I reset the Uno a few times and now it errors like so:
Trinket loader!
Reading signature:930B
Found "blankfull.hex" for attiny85
Setting fuses Set Low Fuse to: F1 -> A000 Set High Fuse to: D5 -> A800 Set Ext Fuse to: 6 -> A400
Verifying fuses...
Low Fuse: 0xF1 is 0x0
Failed to verify fuses
Any thoughts? Thanks!
Seems like it must be a connection problem. Verify that you have solid connections, according to the tutorial. If you're using alligator clips, try some different ones (or at least check them for continuity with a multimeter).
https://learn.adafruit.com/introducing- ... bootloader
How are you handling the reset pin? Have you soldered on a wire?
aramys
Post by aramys »
Same Deal Over and over I've tried the instructions for repairing the boot loader and am still getting an image fail error.
Screen Shot 2014-10-25 at 8.54.53 PM.png (39.06 KiB) Viewed 706 times
adafruit_support_mike
Same suggestions: double-check all your connections, and try another USB cable if you can find one. It's amazing how often the cable is the problem.
Do you always get a reported signature of 200?
aramys
Post by aramys »
OK, I bought the cable from here as well, so it's brand new. Yes I always get a 200. Just got a new trinket will try with that one. If it's the problem then it's very likely the cable. Will keep posting.
mcmasterp
Post by mcmasterp »
I accidentally hooked up a 9v battery to the 5v pin instead of the bat+ pin on my trinket pro. my potentiometer smoked a tad. not good. So now when I hook up the battery to the correct pins the pin 13 led blinks 3 fast blinks over and over. if I plug in the usb for power it pulses like bootloader but maybe a bit faster and never stops. I tried reuploading my sketch but it fails with error:
avrdude: verification error, first mismatch at byte 0x0000 0x0c != 0xcd avrdude: verification error; content mismatch
is it hopeless? did I burn it out? I want to try to repair the bootloader but I only have trinket pros'. can I use a trinket pro to program a trinket pro?
Doesn't sound good.
We don't have a procedure for repairing the bootloader on the Pro Trinkets
mcmasterp
Post by mcmasterp »
Boo. Well lesson learned. Thankfully they are only $10 each. To be clear running one on a 9v battery is fine though right?
mcmasterp wrote:To be clear running one on a 9v battery is fine though right?
Yes, that's fine.
maldemer
Post by maldemer »
I kept getting "Failed to verify fuses" while trying to restore the bootloader on a 3.3V Trinket using a Duemilanove. I came across some instructions to do the same with a hardware programmer, and it was suggested that for 3.3v Trinkets, 5V should be connected to the 3V pin on the Trinket, not VBAT+. I made this change and the restore was immediately successful. Maybe the voltage regulator was interfering with resetting the fuses?
