Donkey Kong modded to take pennies, nickles and dimes
by blackie on Thu Nov 21, 2013 10:27 am
I used a programmable coin acceptor, a trinket and relay to mod my Donkey Kong cab so it will take pennies, nickles and dimes.
The Adafruit Programmable Piggy Bank code only needed a few small changes.
* connect the COIN wire to digital 2
* set the side switches to "FAST" "NC"
*Program so penny = 1 pulse
*            nickle = 5 pulses
*            dime = 10 pulses
*            quarter/token = 25 pulses
*connect the RELAY wire to pin 3
// attach coin wire to pin 2
#define COIN 2
// attach relay wire to pin 3
#define RELAY 3
//This will be used to keep track of coin value
int value = 0;
  pinMode(RELAY, OUTPUT);
  pinMode(COIN, INPUT);
  digitalWrite(COIN, HIGH); // pull up
  // while the coin pin is low (no coin detected), do nothing
  while (! digitalRead(COIN)) {
    delay(1);
  // while the pin is high, we'll track the length with a counter
  uint8_t counter = 0;
  while (digitalRead(COIN)) {
       delay(1);
        counter++;
  if ((counter > 60) || (counter < 20))
      return;
 // add to value for each good pulse counted.
  value++;
 // for every 25 pulses, turn relay on/off
   if (value >= 25)
      addcoin();
void addcoin() {
    digitalWrite(RELAY, HIGH);   // turn the RELAY on (HIGH is the voltage level)
    value = value - 25;        // subtrack 25 from value
    delay(50);               // wait for a little
    digitalWrite(RELAY, LOW);
blackie
Re: Donkey Kong modded to take pennies, nickles and dimes
by adafruit_support_bill on Thu Nov 21, 2013 10:49 am
Awesome! Thanks for the post! :D
