nRF24L01+ and Trinket
Has anyone had any luck using Trinkets with nRF24L01+ 2.4ghz transceivers? The one I'm playing around with, specifically is this: http://yourduino.com/sunshop2/index.php ... tail&p=188
- AnneBarela
- Learn User Page
Re: nRF24L01+ and Trinket
It takes 5 pins and Trinket has 5 pins. Not sure the libraries will compile in the space. Also no pins left to really do anything with. I'd be interested if you got it working.
I've been able to get this port of the SPI and mirf libraries to compile and upload to the trinket:TheKitty wrote:It takes 5 pins and Trinket has 5 pins. Not sure the libraries will compile in the space. Also no pins left to really do anything with. I'd be interested if you got it working.
https://github.com/stanleyseow/arduino-nrf24l01
But so far, haven't actually successfully transmitted anything. Very hard to diagnose where the problem is, though (at least with my limited knowledge).
Of course, yeah, the 5 pin thing is going to be a tricky limitation if/when I get this working and want to actually do something with it… might be able to reclaim a pin by not having the trinket be able to do any RX? But I'll cross that bridge when I come to it. For now I just want to get a successful communication test going between a Trinket and an Arduino Uno.
- AnneBarela
- Learn User Page
See the Trinket Audio Player tutorial for a working SPI implementation. I'm not sure you can easily debug without a protocol analyzer or o'scope.
- jodaco67
You can also try one of these
http://www.icstation.com/product_info.p ... sHt2jceWm-
It allows you to communicate with an nRF24L01+ over I2C which will save you pins. By default the interface is limited to passing single bytes but it has a programmable ATMEGA48 on board which can be reprogrammed to suit your needs! In theory you could even write a facade for the MIRF or RF24 libraries to work over I2C and program it to the ATMEGA48.
- AnneBarela
- Learn User Page
I found an interesting article about using the module with a 'tiny85 using only 3 pins and a few components - worth a look:
http://hackaday.com/2014/02/16/nrf24l01 ... ny85-pins/
