Here is my Hexapod :)
by richarduk on Tue Jan 28, 2014 3:09 pm
I built my self a 3D printer over Christmas using the k8200 kit. And of cause, first thing to print, some robot stuff. :)
I used the following hexapod 3d files with a little modification.
5v Trinket
2 micro switchs
And three micro servos.
Here is a video :)
So that I don't have to disconnect anything to upload new code I test for LOW on pin #3 (it has a pull up on it) and test for HIGH on pin #4 ( I added a pull down)
Pins 0,1,2 are for the servos.
Hope you like it. :) And thanks to Kitty and Mike for help with the issues I had. :)
And here is the code.
 #include <avr/power.h>
#define LEGS_MIDDLE_PIN 0
#define LEGS_MIDDLE_RAISE_RIGHT 1650
#define LEGS_MIDDLE_CENTER 1125
#define LEGS_MIDDLE_RAISE_LEFT 1400
#define LEGS_LEFT_PIN 1
#define LEGS_LEFT_FORWARD 800
#define LEGS_LEFT_CENTER 1350
#define LEGS_LEFT_BACK 1800
#define LEGS_RIGHT_PIN 2
#define LEGS_RIGHT_FORWARD 1700
#define LEGS_RIGHT_CENTER 1200
#define LEGS_RIGHT_BACK 700
#define MOVE_PAUSE 250
#define LEFT_TENTACLE 3
#define RIGHT_TENTACLE 4
static bool Tentacle_Both()
    return digitalRead(LEFT_TENTACLE) == LOW && digitalRead(RIGHT_TENTACLE) == HIGH;
static bool Tentacle_LeftHit()
    return digitalRead(LEFT_TENTACLE) == LOW;
static bool Tentacle_RightHit()
    return digitalRead(RIGHT_TENTACLE) == HIGH;
struct Legs
    Legs()
        middle = left = right = 0;
    void setup()
        pinMode(LEGS_MIDDLE_PIN,OUTPUT);
        pinMode(LEGS_LEFT_PIN,OUTPUT);
        pinMode(LEGS_RIGHT_PIN,OUTPUT);
        middle = LEGS_MIDDLE_CENTER;
        right = LEGS_RIGHT_CENTER;
        left = LEGS_LEFT_CENTER;
    void ForwardOneStep()
        middle = LEGS_MIDDLE_RAISE_RIGHT;
        delay(MOVE_PAUSE);
        right = LEGS_RIGHT_FORWARD;
        left = LEGS_LEFT_BACK;
        delay(MOVE_PAUSE);
        middle = LEGS_MIDDLE_RAISE_LEFT;
        delay(MOVE_PAUSE);
        right = LEGS_RIGHT_BACK;
        left = LEGS_LEFT_FORWARD;
        delay(MOVE_PAUSE);
    void BackupRotate180()
        Backup(5);
        // Random left or right.
        if( (millis()&1) == 1)
            RotateCCW(5);
        else
            RotateCW(5);
    void BackupRotateCCW()
        Backup(4);
        RotateCCW(3);
    void BackupRotateCW()
        Backup(4);
        RotateCW(3);
    void Refresh()
        if( middle == 0 )
            return;
        digitalWrite(LEGS_MIDDLE_PIN, HIGH);
        delayMicroseconds(middle);
        digitalWrite(LEGS_MIDDLE_PIN, LOW);
        digitalWrite(LEGS_LEFT_PIN, HIGH);
        delayMicroseconds(left);
        digitalWrite(LEGS_LEFT_PIN, LOW);
        digitalWrite(LEGS_RIGHT_PIN, HIGH);
        delayMicroseconds(right);
        digitalWrite(LEGS_RIGHT_PIN, LOW);
private:
    void Backup(int n)
        while(n--)
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
    void  RotateCCW(int n)
        delay(MOVE_PAUSE);
        delay(MOVE_PAUSE);
        while(n--)
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
    void  RotateCW(int n)
        delay(MOVE_PAUSE);
        left = LEGS_RIGHT_CENTER;
        delay(MOVE_PAUSE);
        while(n--)
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
            delay(MOVE_PAUSE);
    uint16_t middle,left,right;
Legs OurLegs;
void setup()
     if (F_CPU == 16000000)
        clock_prescale_set(clock_div_1);
    OurLegs.setup();
    pinMode(LEFT_TENTACLE,INPUT);
    pinMode(RIGHT_TENTACLE,INPUT);
    // Set up the interrupt that will refresh the servo for us automagically
    OCR0A = 0xAF;            // any number is OK
    TIMSK |= _BV(OCIE0A);    // Turn on the compare interrupt (below!)
void loop()
    if( Tentacle_Both() )
        OurLegs.BackupRotate180();
    else if( Tentacle_LeftHit() )
        OurLegs.BackupRotateCCW();
    else if( Tentacle_RightHit() )
        OurLegs.BackupRotateCW();
    else
        OurLegs.ForwardOneStep();
// We'll take advantage of the built in millis() timer that goes off
// to keep track of time, and refresh the servo every 20 milliseconds
// The SIGNAL(TIMER0_COMPA_vect) function is the interrupt that will be
// Called by the microcontroller every 2 milliseconds
volatile uint8_t counter = 0;
    // this gets called every 1 millisecond on trinket running @ 16MHz
    counter += 1;
    // every 20 milliseconds, refresh the servos!
    if (counter >= 20)
        counter = 0;
        OurLegs.Refresh();
richarduk
Re: Here is my Hexapod :)
by thekitty on Tue Jan 28, 2014 7:07 pm
Richard, this is way cool! Great work!
thekitty
by adafruit_support_bill on Tue Jan 28, 2014 7:15 pm
Excellent job! Amazing what you can do with these tiny processors :D
by jw40 on Wed Jan 29, 2014 7:00 pm
No. Freakin'. Way. This is just incredible.
Breaking stuff since the 70s...
jw40
by richarduk on Thu Jan 30, 2014 3:55 pm
Cool, just seen the post on the blog. [Massive grin on face] :D
richarduk
cron
