USI and neopixel not working in Gemma
inventor
Post by inventor »
Hi
I'm trying to use this library to recommend this post
http://www.adafruit.com/blog/2013/09/30 ... e-trinket/
USI or neopixel work well separately, but not in set, neopixel not working with USI active
Help
Google Translate
egutting
Re: USI and neopixel not working in Gemma
Post by egutting »
It looks like the USI runs off of pins 0 & 1, do you have the neo pixels on one of those pins as well?
inventor
Post by inventor »
I have Neopixel in D2
egutting
Post by egutting »
Could you post the code you are using with the </> button to see if there may be something there?
inventor
Post by inventor »
Yes, i have a Gemma working 8Mhz :)
/* UsiSerial by [email protected]
 * UsiSerial is a simple wrapper around the code from AVR307 so that Arduino can use USI to implement a hardware serial port
 * This is a simple echo example.
 * The USI class works almost exactly like HardwareSerial
 * So you can use print and println and other functions like that
 * PORTB0 is DI, thus it is RX
 * PORTB1 is DO, thus it is TX
 * default baud rate is 19200, which can only be changed in USI_UART_config.h
 * only some baud rates will work, depending on CPU frequency
 * buffers are small to save memory, since this library is designed for ATtiny
 * testing was done using a 16 MHz Trinket
 * Important note: requires Timer1 and PCINT to be occupied
#include <UsiSerial.h>
#define PIN 2 //marked D2 on GEMMA
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(48, PIN, NEO_GRB + NEO_KHZ800);
int sine[] = {4, 3, 2, 1, 0, 15, 14, 13, 12, 20, 21, 22, 23, 24, 25, 26, 27, 28, 36, 35, 34, 33, 32, 47, 46, 45, 44}; //these are the pixels in order of animation-- 27 pixels in total
void setup()
  UsiSerial.begin();
  strip.begin();
  strip.setBrightness(40); //adjust brightness here
  strip.show(); // Initialize all pixels to 'off'
void loop()
  for(int i=0; i<36; i++) {
    strip.setPixelColor(sine[i], strip.Color(75, 250, 100)); //change RGB color value here
    delay(40);
    for (int j=0; j<25; j++){
      strip.setPixelColor(sine[(j+i+4)%36], strip.Color(0, 0, 0));
    strip.show();
  if (UsiSerial.available() > 0) {
    UsiSerial.write(UsiSerial.read());
egutting
Post by egutting »
This may be the issue...in the NeoPixel library it turns off interrupts: Line 97 of Adafruit_NeoPIxel.cpp: noInterrupts(); // Need 100% focus on instruction timing
The hardware serial mentions in the read_me file: Important note: requires Timer1 and PCINT to be occupied.
You need interrupts for the hardware serial to work, but need them turned off for NeoPixels due to the timing.
inventor
Post by inventor »
Then they would not work together? or there would be a solution?
Thank you for your help
You would not be able to use them at the same time. Neopixel updates and interrupts are fundamentally incompatible.
