Can a Trinket be used with a NeoMatrix? I ordered the 5V Trinket and NeoMatrix shield, and when I tried to upload the sample NeoMatrix code to the Trinket, it said that the code was too big (~6K bytes).
Is it possible to run the NeoMatrix on the Trinket? If so, is there some sample code? Do I need all 3 libraries (NeoPixel, GFX, and NeoMatrix)?
- pburgess
Re: Trinket and NeoMatrix
The Adafruit_GFX library is too large for the Trinket (mostly due to the font data).
You can use the regular NeoPixel library, but won't have any of the graphics primitives like lines and rectangles; it essentially works like a NeoPixel strip in a zig-zag arrangement. Basically, only SetPixel(). You could write some wrapper functions to give limited X/Y functionality without invoking the whole NeoMatrix library.
- dannya
Thanks! Can you give me an example of how to modify this code?
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#ifndef PSTR
#define PSTR
#endif
#define PIN 6
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(5, 8, PIN,
NEO_MATRIX_TOP + NEO_MATRIX_RIGHT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_PROGRESSIVE,
NEO_GRB + NEO_KHZ800);
const uint16_t colors[] = {
matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };
matrix.begin();
matrix.setTextWrap(false);
matrix.setBrightness(40);
matrix.setTextColor(colors[0]);
int x = matrix.width();
int pass = 0;
matrix.fillScreen(0);
matrix.setCursor(x, 0);
matrix.print(F("Howdy"));
if(--x < -36) {
x = matrix.width();
if(++pass >= 3) pass = 0;
matrix.setTextColor(colors[pass]);
matrix.show();
delay(100);
- dannya
Never mind, figured it out. Thanks!
