I am trying to get my monochrome 128x32 I2C display to work with my brand new Trinket Pro 5V. I was able to successfully load the blink code onto the trinket so this one looks to work fine. Similarly I could load the corresponding File→Sketchbook→Libraries→Adafruit_SSD1306→SSD1306... on my regular Arduino Uno. The OLED display works exactly as explained in the excellent tutorial at https://learn.adafruit.com/monochrome-o ... 2c-display (I made sure to set the right screen size of the display in the header).
Unfortunately, when trying to connect the OLED display to the Trinket, uploading the same ssd1306_128x32_i2c sketch does not work at all. Compiling is fine but uploading ends up with the following messages:
avrdude: verification error, first mismatch at byte 0x0108
0x00 != 0xff
avrdude: verification error; content mismatch
I have tried to reduce the size of the sketch but that did not change a single thing.
EDIT: I just tried to use a NeoPixel Stick 8 x WS2812 5050 RGB and a similar issue is poping up. Stick is working fine (strandtest) with the Arduino Uno but the Trinket Pro refuses to upload the code.
EDIT2: testing the GPIOs with a single led & resistor works fine.
Any idea? I am running Windows 7 and successfully programmed gemma recently (in case that would conflict?)
Thanks all,
Arnaud
Unable to load sketch for 128x32 I2C OLED display
- narno
- adafruit_support_rick
Re: Unable to load sketch for 128x32 I2C OLED display
I just loaded the ssd1306 example sketch onto my Pro Trinket with no problems. You've probably got a marginal USB cable. Do you have a different one you can try? Also, try a different USB port.
- narno
Hi Rick,
Thank you for your help. I just tried a different cable and a different USB port. No change at all. Still capable of uploding the blink sketch but not more. See pictures of the setup & result.
Note that I am using the LiPo backpack. could this be an issue?
thanks,
Arnaud
thanks,
Arnaud
- Outputs of Arduino sketch upload
- Capture.JPG (102.26 KiB) Viewed 366 times
- Wiring pic
- IMAG0233.jpg (733.98 KiB) Viewed 366 times
- adafruit2
hmm we have loaded up OLED sketches lots of times, lets get you another protrinket - email support@adafruit with a link to this thread to get a new one!
- narno
Hi Adafruit,
I have received the replacement trinket and I am delighted to share that the new one works like a charm!
Thank you again for the support,
Arnaud
Arnaud
Glad to hear it! Thanks for posting
