What is the Power consumption needed when the pro trinket 5v version is in sleep mode? and when in operation?
I am trying to determine battery life and capacity needed for new project.
5v Trinket Pro Power use in sleep mode
- adafruit_support_rick
Re: 5v Trinket Pro Power use in sleep mode
In operation, the current draw depends on what you're doing with it - what functional areas of the chip are enabled, what's connected to the output pins, etc. Assuming no external resistive loads besides the LED, the typical draw will be on the order of 20mA. In full sleep, the only thing really drawing power will be the LED, which I think draws around 4mA.
- dsurgi
can I remove the power regulator and the power led to get more life. and I am using a backpack to charge the battery and provide power to the trinket pro. what is the power consumption of the backpack.
You can remove the power LED. I don't know what the consumption of the backpack is.
- dsurgi
What would be the best way to test the power consumption of the backpack.
Measure the consumption of the trinket with and without the backpack connected, I suppose.
