Is a 5 V trinket capable of sourcing enough current to drive this SSR?
http://www.amazon.com/gp/product/B00HUB ... UL9P0ZZM9V
Can 5v trinket drive SSR?
- adafruit_support_mike
Re: Can 5v trinket drive SSR?
Can't tell without seeing a datasheet. The product page says it can accept 3v to 28v input and handle 40A of controlled AC, but doesn't say how much input current it needs.
- Cmpenney
Hopefully a spec sheet is included with it when it arrives
According to the sheet, it takes input signals of 3v-32v DC with an ON threshold of 2.4v. It requires 7.5mA with a 12v input. Most likely less at 5v..
http://akizukidenshi.com/download/ds/fo ... ek_ssr.pdf
- Cmpenney
If I recall the trinket can handle 150 mA so I should be fine. Correct?
Per-pin, you should try to keep it under 20mA. But you are probably still OK
- cbxbiker61
Just wanted to add that I've driven 4 of those SSRs directly from a Mega256 board, so all is good.
In a later rev of the project, I swapped out the mega board with an esp8266, which required me to use transistors to pump up the current driving the SSRs.
