On Off Switch
- Bill_Brown
On Off Switch
I just purchased a Trinket 5V, and a On/ Off switch. But I need guidance as to where the switch should be soldered to the Trinket. Let me explain my project. I want to turn on a single Superbright 5mm white led. Once turned on I want Trinket to pulse the led slowly. I will be using a single 18650 battery as power. This project is similar to the Tesla walking cane project. Except this is for a Steampunk lightsaber. Any help will be appreciated. This is my first Trinket project.
- Benengel94
Re: On Off Switch
Do you have the power back pack for the trinket? If so then the switch should by put on the two copper circles on the top of the board next to the port. But be sure to scratch off the trace first, the trace acts like a permanent on switch. If you don't have the backpack then you should probably get one if you want to charge up your battery and run the device with no cables attached.
- Bill_Brown
Re: On Off Switch
I do not have a battery pack. I made one myself. I assume the leads for the battery go to Battery and Ground. Then the switch would go where? I plan on taking battery out of tray to charge it.
- adafruit_support_bill
Re: On Off Switch
The switch would be wired in-line with the positive lead from the battery. One pin connects to the red wire on the battery, the other to the BAT pin on the Trinket.
- Bill_Brown
Re: On Off Switch
I understand what you are tell me. But to be sure, could support provide a photo or video of this connection. Please!
- hiduino
Re: On Off Switch
The closest diagram will be something similar to this, https://learn.adafruit.com/3d-printed-e ... it-diagram.
This is using the Gemma but it is similar to the Trinket JST pinouts, which are BAT+ and GND.
Some other examples, https://learn.adafruit.com/3d-printed-l ... it-diagram.
https://learn.adafruit.com/3d-printed-c ... it-diagram
