for a friend with a severe disability, I assembled EZ-Key HID.
I have connected a button to inputs 0 and 1 (in short-cut). I configured the two inputs to the keys Left-ALT and Right-Arrow, .
I paired the device EZ-Key to iPad via Bluetooth.
I enabled Voice Over on iPad.
I started iBook and opened a book.
Pressing the button, the pages go on.
Voiceover enables the keyboard (bluetooth) to send commands to the iPad.
If I send the keys Left-Alt + Right-Arrow, pages of the ibook are moving forward.
My friend was not able to turn the pages of a book on the iPad and now he can do in full autonomy! Thanks to this device! It’s not wonderful?
However I encountered a problem that I hope someone can help me solve.
Not always the pages slide forward one by one.
If the button is pressed too quickly, nothing happens or the focus moves forward. But the page does not change.
If the button is pressed for a longer time, so many pages run forward.
It is really hard to press the button for the exact time to advance only one page!
I would like to know if it is possible to lock the repetition of the Right-Arrow key
Thanks for your help
Riccardo
Attached are photos of the device.
There are two input for the button: one is used to read the books trough iBooks, the other is used to read through the comics Mickey Mouse (It use UpArrow+Down Arrow to move forward).
There is also a small breadboard used to recharge the Li-ion battery via USB cable
Lock Key repetition in EZ-Key
- giocamela
- Attachments
- IMG_2192.JPG (68.84 KiB) Viewed 536 times
- IMG_2191.JPG (94.32 KiB) Viewed 536 times
- IMG_2190.jpg (144.23 KiB) Viewed 536 times
- Franklin97355
Re: Lock Key repetition in EZ-Key
Thank you for posting. What a great project!
- adafruit2
Great project! thank you so much for telling us about it. The unfortunate thing is that key repeat is handled completely by the iOS software. the bluefruit just sends a key down when the button is pressed and a key up when the button is released.
you can solve this, but you will need to use a microcontroller like a Trinket: the trinket would listen to the button press on one pin and when it sees the press, sends a short press (down, wait 10 milliseconds, up) on the EZ-Key. so even if the button is held down, it only sends a short press. does that make sense?
- giocamela
Thank you for your compliments on my project.
I think a microcontroller as Trinket could be a solution.
I'll try it.
Thank you for your suggestion
I'll try it.
I ran into the same problem as you when trying to make an iPad switch interface. I got as far as you did and had the key repeat problem. I bought a Teensy to use as the microcontroller, but got lost when trying to figure out how to implement it into my project. If you get your project to work would you be able to provide step by step instructions and any necessary code? Much thanks.
- giocamela
Certainly. as soon as possible. I'm working with a trinket, but the code should work the same.
