I would like to know if the fona 808 https://www.adafruit.com/product/2542 comes with the IC S2-1060C-Z1F02 or the previous version (ZIV01) and what is the difference between them.
I would also like to know if this SIM808 supports full SSL since I need to connect to a server via HTTPS requests.
Thank you in advance.
Fona 808 Version
- DYNAMASOL
Re: Fona 808 Version
Srs Adafruit,
I am still awaiting the answer of this question so I can place my order. I need the ZIV02 version of the SIM808.
- adafruit2
Hiya, the breakout is still V1 (the shield version is V2). The difference is in the GPS chipset, apparently the V2 is *slightly* faster to fix, maybe a second or two. The command set is slightly different as well.
the fona modules do not appear to have SSL
- adafruit2
pardon, apparently you can do https SSL but not for other protocols
https://github.com/adafruit/Adafruit_FO ... .cpp#L1422
- tictag
SIM808 (FONA 808) doesn't support HTTPS but SIM 5320 (FONA 3G) apparently does. Refer to section 16.5 in the ATC datasheet (http://simcom.ee/documents/SIM5320/SIMC ... _V2.02.pdf)
