hello,
My gps is not working, does anyone know why?? I configure it in the 3 different ways: standalon ,u-based mode and u-assisted mode . I have connected the antena, i have no idea what is happenening
GPS FONA 3g NOT WORKING
- blodtann
Re: GPS FONA 3g NOT WORKING
A few things to check; are you using an active antenna? If so you have to solder the bias on the module.
You also need to be outside with the antenna or right next to a window with a clear view of the sky.
I would highly recommend using an active antenna, a fix with a passive antenna can take minutes.
There are only two commands needed to be able to use the GPS;
AT+CGPS=1
Wait a while then
AT+CGPSINFO
AT+CGPS=1
Wait a while then
AT+CGPSINFO
- emoyers
I bought the antenna in adafruit, also the conector between the antenna and the simcom board. I haven`t solder the conector to the board. Do I have to solder it?
I attached somo photos of my conections.
- blodtann
If this is this antenna;
https://www.adafruit.com/products/960?g ... oCFdvw_wcB
Then it is an active antenna and you need to solder the pads together labeled 'bias'
Read this for reference;
https://learn.adafruit.com/adafruit-fon ... ut/pinouts
- blodtann
And you are probably never going to get a GPS fix inside your house if that's where the antenna is placed. Put it outside or right next to a window.
- emoyers
yes is an active antenna. what i'm understand is to solder this jumper
. Am I right?Please be positive and constructive with your questions and comments.
