Firmware won't load. ... Same as gompie i guess
Order a programmed cpu or, finf someone who can load the boot thingy
antto wrote:in gompie's case, he does have firmware (and i think bootloader too) but the data from the x0x over the serial port somehow turns into zero bytes, we suspect something might be wrong with the USB chip or the connections around it
antto wrote:no problem
antto wrote:paste the log file contents on something like pastebin.com and post the link
antto wrote:the bootloader .hex is here: http://x0xb0x.cvs.sourceforge.net/viewv ... ootloader/
there's also the "x0xb0x_full.hex" which i guess is the firmware + bootloader
as for the log, i there is only out-going data, and no reply from the x0x, so it appears as if nothing is on the other side
antto wrote:since you connected to the serial port, then the usb-serial driver is working
it's the x0x that doesn't respond, so yeah there isn't any firmware and/or bootloader on it
gompie wrote:IT NOW WORKS!! So glad the USB chip was the issue. In the kit I received to build the x0xb0x the IO-board came with the USB chip already on there. In the end it did not save me much time, because it was BROKEN!![]()
So, put a new USB chip on there today and OMG: c0nb0x works as promised and I've been able to put sokkOS 2.0 on there in one run!Thanks for the program and all the help you guys!
Users browsing this forum: No registered users and 4 guests
