I am just about finishing a selfsourced xoxbox.. I had to do the casing my self because no quick way to get to the intended housing... but thats finished now and i will see tomorow if it is running straight away...
I made a test with the new transistors in position Q9 of my old original 303... they sound different even when having betas above 350... but the different sound was pleasing to me... i will investigate that a bit mre in my xox unit ...after confirming that its working i will place sockets for positions Q8-10 and see what combinations do what..
lokking into the availible manuals left a few questions open...
there is no syncing via USB...ist that wright?
In case thats wright i wonder why..is it a limitation of the design or is it just a operating system question?
Somwhere in the Forum i ve readthat the sokos OS 1.9 dont worls in midi sync..is that wright? Is there an updated version around?
And how does the Sokos OS behave in general? HAve many users went for this custom OS? Or is it risky?
The 2 features that that the slide/acc switches are only temporarely and that you can save where you want..having pattern copy this way, are most important for me... Swing is nice as well..but i guess thtas the part where timing problems can come from...
Has anybody done a merging of OS systems or are ther OS versions around that just have little improvments like the save where you want routine??
In the end of the day this probably makes the biggest workflow benefit...
As i understand you need the control software to dump patterns..but as i read in the forum it is not working at all..
and not on a mac...
Is this old info and somebody has fixed that allready? If yes it would be nice if somebody could supply me with links..
Thanks,
Sven
