Midi sync and edit pattern simultaneously?
x0x0x0x0x0x
redlotus
Post by redlotus »
Hey everyone,
I just got an xoxbox and after abandoning a midi sync with ableton I synced it up to some other gear and it worked well.
It sounds sweet.
However I have discovered that I can't edit while it is midi synced.
Is there a way to have the xoxbox synced up to other hardware as slave or master and also be able to edit notes? eg edit the pattern while its playing along with a korg ea1?
Without hearing my patterns synced and mixed in with the song it is hard to tweak them.
Adjusting them without the track is a bit hit and miss and can be very time consuming. Surely there is a way to tweak a pattern (and I don't mean the knobs :P ) while the device is midisynced and playing?
Any advice would be appreciated.
If it cant be done I will have to fire up Rebirth and do my pattern creating there.
Cheers.,
Redlotus/
jfx09
Re: Midi sync and edit pattern simultaneously?
Post by jfx09 »
Well, keep in mind I don't have one yet, but, the manual states:
Editing Patterns in Run-write Mode
Run-write mode allows you to listen to the pattern and modify it 'on the fly.' New notes cannot be added in run-write mode, neither can the pattern be shortened. The tempo at which the pattern is 'run' is set by the tempo knob (no other syncs are available).
seems like it won't do it
paradigm x
Post by paradigm x »
you can with the SokkOS fimrware upgrade, search on here in Mods.
Luap
Post by Luap »
Indeed. Get Sokkos on there. It does what you want, and a ton more useful stuff besides.. :wink:
redlotus
Post by redlotus »
Cool thanx for the nfo.
It's great that this functionality has been added. :)
Ill check out the Sokkos upgrade.
Cheers,
Freq.
altitude
Post by altitude »
what happened to the modded original firmware that had this in "user A" that Limor did? During the first run I thought this was implemented (the c0nsumer overlays had it in the legend) but it something must have happened after that..
astroschnautzer
Post by astroschnautzer »
So no pattern edit and midisync available at same time in any os? Really?
altitude
Post by altitude »
astroschnautzer wrote:So no pattern edit and midisync available at same time in any os? Really?
No. It's on SokkOS and most modded firmwares.
astroschnautzer
Ok, I just didn't get it to work then in sokkos 1.9.something. Have to try tomorrow again ...
altitude
Post by altitude »
start it in sync mode then just turn the switch to pattern edit, thats all there is to it.
astroschnautzer
Ok, thanks.
antto
Post by antto »
i think Pat.Edit(MIDISYNC) is also there in adafruit's 1.05 firmware (user A mode)
Return to “General x0xing”
