it varies from 0 to 2,4V im checking if this has something to do with the software not loading or I have a faulty pot.guest wrote:yes
when measuring voltages it needs to be on
if you put your probe on the center pin
of the cutoff pot
it should vary from 12v to 4.5v
edit1: the working filter pot of the other box goes from 0 to 7V, so basically the same range as 4.5 to 12v, dont know why my multimeter shows 0 to 7 volt - interestingly the env mod knob of both boxes share the same characteristics as the first one which goes to about 2,4V, but they all are labelled A50K - is it possible that there are pots with different volt ranges but identical labeling, or maybe there is additional information below the pots, dont wanna loosen them now with the solderin iron, which btw is quite a hazzle I found out
Or is it possible that wrong a wrong resistor causes this measurement difference? I doubt it, but I am not skilled at electronics, its about 10 years ago in school when I learned those basics
I tried to solder out the working pot and put it into the faulty box, but I did not manage phisically! I mean how do you loose 5 contacts at once? pheew...Is there a trick to it that I dont know of?
greets
nature
edit2...hm well maybe I take an old TRS cable and bridge the contacts of the working one to the faulty one, leaving that one in 0 position, so I could see if the box adapts the higher control range...
edit3: this is so strange, on ladyada it says I need 2 50K D (log) potentiometers for VR3 (cutoff) and vr5 (envmod) which would mean that my working xox with the bigger cutoff range has different pots, as one goes to 7v and the other has the 2,4V...so strange, dont know anymore which box has a problem - well the first with the bigger range sounds right! the other one not, though the other one has on vr3 and vr5 a 2,4V range, so it seems their pots are identical...so strange. going to check all resistors now... :/
eidt4: uhm, did you get the news of some weeks ago? china wants to build 40 new nuclear powerplants Oo that might be a bit tougher than assembling a xox ^^
edit 5: some success: R47 is differing also visually from one to the other box, it looks connectd to vr4 though
