Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
loss of volume with opened resonance
by bodytwist on Fri Apr 27, 2012 5:03 am
first thank you so much for the X0xb0x and your very active community. i've bought a X0xb0x hand made and perfectly tunes/built. (x0xconcept, france)
As i can remember the original 303 have a "special" filter that avoid the loss of volume when the resonance is opened, but i'm not sure as i haven't seen any 303 since 1990 !
Here, i've a big loss of volume power (about 6dB) when the resonance is turned to wide open, i just want to know if it's normal (i can compensate that with a hard compression after the Xoxbox, but i would prefer not to use so much compression).
Thank you in advance.
BT
ps : thanks to the developpers of c0ntr0l and safeb0x, too.
bodytwist
Re: loss of volume with opened resonance
by antto on Fri Apr 27, 2012 1:19 pm
yes, the gain loss is part of the filter
unlike the moog ladder, this diode ladder filter needs more feedback to get into selfoscillation, and thus it loses more gain compared to the moog ladder
the 303/x0x does have a gain compensation internally, but it's not much
antto
by bodytwist on Mon Apr 30, 2012 3:19 am
not big problem actually, thank you for your answer :)
bodytwist
by mome rath on Tue May 01, 2012 10:48 am
bcbox posted a solution for this, which was to replace a capacitor... but I don't recall which one/with what value :lol:
forum search or x0xb0x wiki should help you find the answer
mome rath
by bodytwist on Tue Sep 25, 2012 10:54 am
okay, thank you for the tip, sorry for the time i took to answer. Finally i find a solution using a soft settings in some cheap compressor (bluemax/presonus), it works cool and does not affect the sound that much.
bodytwist
cron
