Re: c0nb0x
by antto on Wed May 01, 2013 7:24 am
i cannot answer because i don't have osx
but you can download it and try to run it, if it runs - it runs ;]
antto
Re: c0nb0x
by Chris72160 on Wed May 01, 2013 7:53 am
Ok. I`ll try. :P
Greetz Chris
Chris72160
Re: c0nb0x
by alejappo on Thu May 30, 2013 5:57 pm
hello!!!
I tried to upload firmware with c0nb0x...
result???? my xox is frozen.... switch on... some led casually lights on... but nothing move...
the software see the xox by serial port...
help me please
alejappo
Re: c0nb0x
by antto on Thu May 30, 2013 8:18 pm
well, did c0nb0x complete the upload or did it print some error?
antto
Re: c0nb0x
by alejappo on Fri May 31, 2013 1:03 am
knock knock ... error etc etc ...
retry and again the stop loading ...
my xox is frozen... every func dont start!
alejappo
Re: c0nb0x
by alejappo on Fri May 31, 2013 2:05 am
I follow the test guide... in all section ... and finally my xox doesnt work ...
please help me!
I hope in your helpfull
alejappo
Re: c0nb0x
by alejappo on Fri May 31, 2013 2:38 am
pc said me: ARE YOU SURE IN BOOTLOAD MODE?
yes i'm in bootload ...
alejappo
Re: c0nb0x
by antto on Fri May 31, 2013 4:49 am
okay, to clear things up
- at first, your x0xb0x was working in all modes (pattern play, random mode, pattern edit, etc..)
- then you ran c0nb0x and tried to update the OS - what did c0nb0x do exactly?
antto
Re: c0nb0x
by alejappo on Fri May 31, 2013 5:36 am
is possible make a video of this situation???
alejappo
Re: c0nb0x
by antto on Fri May 31, 2013 2:27 pm
this video demonstrates the main things you need to know:
http://www.youtube.com/watch?v=9LuWMUQQ750
antto
Re: c0nb0x
by alejappo on Fri May 31, 2013 3:34 pm
ok...!
soon I make a video for my situation ...
alejappo
Re: c0nb0x
by alejappo on Sun Jun 02, 2013 6:46 pm
i've try and retry but nothing... conbox tell me: KNOCK KNOCK ETC ETC ERROR ...
I watch and follow the video guide on youtube but this insnt my problem ...
my xox not respond!! in every funcs ... it doesnt play !!!!
please help me to go out of this fu******* situation !!!!
I want start from zero...
alejappo
Re: c0nb0x
by antto on Sun Jun 02, 2013 7:12 pm
probably the bootloader has gotten corrupted :?
antto
Re: c0nb0x
by alejappo on Mon Jun 03, 2013 12:26 am
What should I do?
show me the procedure starting from zero.
I have a W7.
thanks
alejappo
Re: c0nb0x
by antto on Mon Jun 03, 2013 6:17 am
well, the procedure..
first you have to install the USB<->Serial drivers from FTDI, this is for the x0xb0x to be recognized as a "Serial port" device in the OS
then, you plug the x0xb0x via USB and it should be recognized
then, run c0nb0x and configure the port name to match the port name of this new serial port
from that point, it should work
i've written these instructions in the c0nb0x readme file too iirc
but if your cpu has gone corrupted (i'm not 100% sure, but that's how it looks) you can do 2 things:
1) use a "programmer" device to erase the chip and program the bootloader again
2) buy a new cpu which is pre-flashed with the bootloader
antto
