Re: c0nb0x
by evostars on Mon Jun 11, 2012 6:07 pm
:( I'm not lucky today.
Firmware won't load. ... Same as gompie i guess
Order a programmed cpu or, finf someone who can load the boot thingy
evostars
Re: c0nb0x
by antto on Mon Jun 11, 2012 7:18 pm
in gompie's case, he does have firmware (and i think bootloader too) but the data from the x0x over the serial port somehow turns into zero bytes, we suspect something might be wrong with the USB chip or the connections around it
antto
Re: c0nb0x
by evostars on Mon Jun 11, 2012 7:52 pm
antto wrote:in gompie's case, he does have firmware (and i think bootloader too) but the data from the x0x over the serial port somehow turns into zero bytes, we suspect something might be wrong with the USB chip or the connections around it
Ok, just found out al(14) of the 2.2k's are 22k's .
Maybe it will help changing them
evostars
Re: c0nb0x
by gompie on Wed Jun 13, 2012 3:41 am
Correct. I've orderd a new USB chip (FT232BL, replacement for FT232BM, similar pin-out but lead free). I hope FedEx will reach my door on friday, so I can check during this weekend if this was the issue all along.
I have provided Evo with a link to the altered c0nb0x executable you compiled, to check the output on his USB connection, I hope you're ok with that. To me it was a great help to have some more information about what is actually going on. Otherwise with so many variables its very hard to isolate the problem, and its very easy to make a lot of assumpions.
gompie
Re: c0nb0x
by antto on Wed Jun 13, 2012 8:24 am
no problem :wink:
antto
Re: c0nb0x
by evostars on Wed Jun 13, 2012 8:33 am
antto wrote:no problem :wink:
Cool :-)
I got the data, but i cant understand. Lots of zero's though
evostars
Re: c0nb0x
by antto on Wed Jun 13, 2012 10:11 am
paste the log file contents on something like pastebin.com and post the link
antto
Re: c0nb0x
by evostars on Wed Jun 13, 2012 11:23 am
antto wrote:paste the log file contents on something like pastebin.com and post the link
here it is:
http://pastebin.com/6GcZCZFq
I found someone who can put the bootloader and firmware on my CPU. But now I only need the bootloader file. Can someone help me out ? cant find it... only pages full of code
evostars
Re: c0nb0x
by antto on Wed Jun 13, 2012 1:14 pm
the bootloader .hex is here: http://x0xb0x.cvs.sourceforge.net/viewv ... ootloader/
there's also the "x0xb0x_full.hex" which i guess is the firmware + bootloader
as for the log, i there is only out-going data, and no reply from the x0x, so it appears as if nothing is on the other side
antto
Re: c0nb0x
by evostars on Wed Jun 13, 2012 2:33 pm
antto wrote:the bootloader .hex is here: http://x0xb0x.cvs.sourceforge.net/viewv ... ootloader/
Nothing on the other side? Like no software,or no usb port?
evostars
Re: c0nb0x
by antto on Wed Jun 13, 2012 3:12 pm
since you connected to the serial port, then the usb-serial driver is working
it's the x0x that doesn't respond, so yeah there isn't any firmware and/or bootloader on it
antto
Re: c0nb0x
by evostars on Wed Jun 13, 2012 3:15 pm
antto wrote:since you connected to the serial port, then the usb-serial driver is working
Ok thats good news for me. Tomorrow ill meet someone who will put the bootloader and firmware on :-)
evostars
Re: c0nb0x
by gompie on Thu Jun 14, 2012 11:28 am
IT NOW WORKS!! So glad the USB chip was the issue. In the kit I received to build the x0xb0x the IO-board came with the USB chip already on there. In the end it did not save me much time, because it was BROKEN! :shock:
So, put a new USB chip on there today and OMG: c0nb0x works as promised and I've been able to put sokkOS 2.0 on there in one run! :D Thanks for the program and all the help you guys! 8)
gompie
Re: c0nb0x
by evostars on Thu Jun 14, 2012 12:12 pm
gompie wrote:IT NOW WORKS!! So glad the USB chip was the issue. In the kit I received to build the x0xb0x the IO-board came with the USB chip already on there. In the end it did not save me much time, because it was BROKEN! :shock:
That's great news! Enjoy it :-)
evostars
Re: c0nb0x
by antto on Thu Jun 14, 2012 12:36 pm
i'm glad to hear this :mrgreen:
enjoy
antto
