Tuning x0xb0x
Tuning x0xb0x
by philip_morison on Sat Sep 01, 2012 12:10 pm
Have followed what previous post say about tuning vco'c with tm 4 and 5.
I don't have a pc so cannot use the vst tunning plugin.
i have no access to a occiliscope so have been tuning with a chromatic tuner.
everytime i tune one end of the octave to C, the next octave at C has slipped out, so tuning that back to C the octave previously tuned slips out. Going back forth between doesn't seem to do anything just shift the whole tuning of the octave up and down. Can't seem to caliberate these and get them so they are fixed and do not create this domino effect that i previously read in another post.
Is it my tunning technique or could there be something wrong with the componants i.e tm4 or 5
Any can help !!!!
philip_morison
Re: Tuning x0xb0x
by antto on Sat Sep 01, 2012 1:28 pm
well, you're doing it the hard way
even if you don't have any helping tools (scope or the vst plugin..) you can tune it by ear in 2 simple steps
program C notes at different octaves, play the pattern
step #1
tweak TM5 till the C notes sound as 1 octave appart
step #2
play a reference C tone (from your daw or some tuned instrument) and tweak TM4 till it sounds the right frequency
Note: first complete step 1, ONLY then go to step 2...
Note: step 2 isn't too important cuz you can compensate for it at any time with the TUNE knob on the front (that's what it is for)
and DON'T try to be perfect, it's analog, it will always be off
if it doesn't sound "off" to your ear - it's good enough :wink:
antto
Re: Tuning x0xb0x
by antto on Sat Sep 01, 2012 1:32 pm
actually, there's something that can help you in step1
put the x0x thru a feedback delay (either a pedal or from your DAW..)
mix the delay 50:50 with the dry signal and set the delay time to about 1 note
so when your x0x plays a C note - the delay is giving the previous C note (which is on a different octave)
feedback isn't needed, but you can try if it helps
so now, as you tweak TM5 - as you get closer to getting all C notes to be 1 octave apart - you will hear less "beating" and/or "phasing" from the delayed version
hope this helps
antto
Re: Tuning x0xb0x
by MMM on Sat Sep 01, 2012 5:54 pm
philip_morison wrote:i have no access to a occiliscope so have been tuning with a chromatic tuner.
Try the following: Try to tune the "basic" octave C to C untransposed. Once it is in tune check the chromatic notes of that scale. Are they all in tune as well? Pay attention especially to the step G# to A.
If you find any anomalies here please report back.
MMM
