MIDI sequencing external synth problem
by mossy on Sat Nov 10, 2012 9:30 pm
I really hope someone can help me with this problem. I want to use my xoxbox's midi out to play my xoxbox patterns on an external synth. It works but as well as playing the programmed notes it is making the external synths produce unwanted noise on the rests too. Kind of a very low rumble with a click too when it should be silent :(
I don't have a clue how to solve this. It is definitely something to do with the xoxbox coz it does the same with all my synths (juno 106, microkorg, minitaur).
pleeeease help me!!
mossy
Re: MIDI sequencing external synth problem
by mossy on Sun Nov 11, 2012 10:27 pm
so I figured I might have to update the firmware. I have a willzyx x0xb0x which I think has the original .1.05 firmware.
I am trying to update the firmware to sokkOS on my mac using the x0xcon software. I got x0xcon running but can't get it to connect to the x0xb0x. I downloaded some drivers but it's still not working. It's just not connecting.
Can anyone tell me exactly which driver I need? I have trawled the forums but I can't figure this stuff out because my computer knowledge is very limited!
What a nightmare! I just wanna make some tunes. please help meeee!!!
mossy
by roxxx303 on Mon Nov 12, 2012 5:08 am
mossy wrote:so I figured I might have to update the firmware. I have a willzyx x0xb0x which I think has the original .1.05 firmware.
I am a little bit confused... The standard 1.05 firmware should be able to send midi-notes to an external Synth in "midi-play"-mode!
What do you do exactly? Which x0xb0x mode do you use?
Just a x0xb0x with a midi-cable connected from x0xb0x midi-out to midi-in in your external synth? No other connection? No connection from midi-out of the synth to midi-in of the x0xb0x!
And in the audio-out of the external synth you hear unwanted noise or what?
No computer involved?
And what do you mean by x0xc0n? I only know of c0ntr0l or c0nb0x!
Please explain exactly what you do and we try to help you!
roxxx303
by mossy on Mon Nov 12, 2012 7:50 am
thanks for the reply. I'll try to explain better.
My x0xb0x is sending the midi notes fine but it's also sending other midi notes I don't want it to. It sounds like maybe it is sending a midi note on the RESTs in the x0xb0x pattern. So the external synths make unwanted noise in the silent parts of my x0xb0x patterns.
I thought this maybe some kind of firmware bug so I've been trying to update my firmware to sokkOS using conb0x (sorry I made a mistake before, this stuff is wrecking my head!!).
I am using a mac on osx 10.8 and I got conb0x running but can't get it to communicate with the x0xb0x. I don't know if I downloaded exactly the right USB drivers or what I'm doing wrong.
As you can see I'm not an expert on this technical stuff. Are people having success updating the firmware using conbox on the mac?
mossy
by mossy on Mon Nov 12, 2012 8:40 am
I DID IT!!! IT WORKS.... WOOOO HOOOO!!!!!!!!
mossy
by roxxx303 on Mon Nov 12, 2012 9:13 am
mossy wrote:I DID IT!!! IT WORKS.... WOOOO HOOOO!!!!!!!!
What works now? The c0nb0x or the os update or the midi out?
Please explain!
roxxx303
by mossy on Mon Nov 12, 2012 9:25 am
I managed to do the firmware update (randomly it decided to work suddenly) and that fixed my initial problem. sweeet! time to make some tunes!
respect to the x0xb0x community... RAVE ON :mrgreen:
mossy
by roxxx303 on Mon Nov 12, 2012 9:48 am
mossy wrote:I managed to do the firmware update (randomly it decided to work suddenly) and that fixed my initial problem. sweeet! time to make some tunes!
So the 1.05 Firmware has a midi-out-mode bug?
Didn't knew that - but I use sokkos anyway!
Regards!
roxxx303
by antto on Mon Nov 12, 2012 10:22 am
roxxx303 wrote:I am a little bit confused... The standard 1.05 firmware should be able to send midi-notes to an external Synth in "midi-play"-mode!
correction: MidiPlay mode is when the x0xb0x sequencer is not used, and the x0xb0x acts as a monophonic synth - takes midi notes and plays them
sending midi notes Out happens always when the internal sequencer controls the x0xb0x
the sequencer usually also sends midisync together with the notes
so the issue here could have been related, who knows
antto
by roxxx303 on Mon Nov 12, 2012 10:33 am
You're right: "Pattern (Sync out)"-mode is the right mode! I mixed up the names (there are too many modes - and I don't even know what for the user modes are, when theres is even not enough memory left for the basic modes!)
I had problems with Synths receiving midi-sync-data and creating such "ghost"-notes (My Novation Drumstation does so!)
roxxx303
