G is for GROUND! The latest Circuit Playground is here!
Most stable x0x FW for use with midi and dinsync.
by safetyboy on Thu Jan 10, 2013 3:40 pm
What is the most stable FW at the moment that lets x0x take midi in and output dinsync at the same time.
I am using Omsk latest FW at the moment but jumps out of sync every so often
viewtopic.php?f=13&t=27432
Cheers
safetyboy
Re: Most stable x0x FW for use with midi and dinsync.
by antto on Thu Jan 10, 2013 5:45 pm
maybe some of you guys who have other gear besides the x0x, should test and figure the answer to this question
i can't..
antto
by roxxx303 on Fri Jan 11, 2013 4:32 am
safetyboy wrote:What is the most stable FW at the moment that lets x0x take midi in and output dinsync at the same time.
Cheers
Without swing: it's Sokos1.9.1.
With swing: have you tried MarOs1.4.1?:
http://forums.adafruit.com/viewtopic.php?f=13&t=33914
roxxx303
by bmot on Fri Jan 11, 2013 2:51 pm
i'm using the latest sokkos release, rarely have any glitches. My preferred setup is as a slave to RS7000, sending DIN Sync to a TR-707.
bmot
by safetyboy on Fri Jan 11, 2013 3:08 pm
c0nb0x keeps giving me the error
so i tried programming the chip with my programmer http://www.advin.com/eprom-programmer/e ... r-580A.htm
Loads firmware fine, but when i put the chip back in the x0x it doesnt work, tried burning a few different FW and all the same. dead x0x
Is the bootloader contained in the FW? or how can I get the bootloader back on the chip.
safetyboy
by antto on Fri Jan 11, 2013 3:57 pm
the firmware .hex don't contain the bootloader but only the firmware
since you have the programmer, you can flash the bootloader, you can obtain it from the x0xb0x files at sourceforge
antto
by safetyboy on Fri Jan 11, 2013 4:07 pm
antto wrote:the firmware .hex don't contain the bootloader but only the firmware
This is what I want to hear :~)
can you explain how to do this, sorry I'm a bit new to this bootloader stuff. I flashed realeoin's chip who you were helping and it worked, I just need to know how to combine the bootloader and the FW.
Cheers for the help.
safetyboy
by antto on Fri Jan 11, 2013 5:41 pm
http://x0xb0x.cvs.sourceforge.net/viewv ... ootloader/
x0xb0x_boot.hex should be only the bootloader, then you use c0nb0x to flash firmware
x0xb0x_full.hex should be combined bootloader+stock_firmware (not sure which version)
ehm, in both cases, after you got the bootloader flashed - you should be able to use c0nb0x to flash firmware via USB
antto
by safetyboy on Fri Jan 11, 2013 5:45 pm
antto wrote:http://x0xb0x.cvs.sourceforge.net/viewvc/x0xb0x/bootloader/
I'm buying you a Guinness if this works...
safetyboy
by safetyboy on Fri Jan 11, 2013 5:51 pm
Knock knock error :(
It opens as a text file, should i save them as .hex?
safetyboy
by antto on Fri Jan 11, 2013 6:45 pm
you mean it opens as text in your browser?
chose File > Save Page As
antto
by safetyboy on Sat Jan 12, 2013 8:09 am
It save as .txt so i renamed it as .hex and still getting Knock Knock. :?:
safetyboy
by safetyboy on Sat Jan 12, 2013 10:01 am
do i need to change anything here?
edit: so I ticked all the boxes and I managed to get the full original FW on the x0x from the link you posted earlier, now i can read the x0x on c0nb0x but I still can't upload new FW.
getting closer :D
safetyboy
by antto on Sat Jan 12, 2013 10:35 am
no idea about this app, i don't have a programmer and have no idea how this works
all i know is that the bootloader should be located in the last 512 bytes of the flash memory
antto
by safetyboy on Sat Jan 12, 2013 10:39 am
antto wrote:no idea about this app, i don't have a programmer and have no idea how this works
I have a working x0x again with original FW at least for now.
safetyboy
