Power supply problems...
by futureanalogue on Thu Feb 21, 2013 5:12 pm
Hi there. got a new x0x (atomic mods) recently but having some power issues.... :evil: .I dont know much about how these work....
when i tried this with a 9v adapter it powered up but did not play the notes properly at all...after a while i got frustrated and turned the multi adapter up to 12v and it now works..????
Is this something to do with the psu i am using..? I just found out it is supposed to be 500mA but this one is 1200..!!!!
Also when i touch any switch it makes a horrible buzzing noise... :twisted:
Thanks in advance..Graham.
futureanalogue
Re: Power supply problems...
by antto on Thu Feb 21, 2013 6:55 pm
it smells like your adapter is DC-DC, which is wrong
the x0xb0x needs DC-AC (9V AC at around 300 to 500mA)
antto
by futureanalogue on Sun Mar 24, 2013 3:46 pm
yeah i was guessin it was the psu...i got a proper 500ma adaptor and it worked fine for a while, but then i connected it to my pc to do an update(a should have bloody left it) this has now pretty much bricked it. :(
when i turn it on a couple of random leds light up and nothing works....!
Please help
Graham
futureanalogue
by antto on Sun Mar 24, 2013 4:38 pm
hm.. what app did you use to upload the firmware?
did you try switching the x0x on/off while the FUNC knob points to "RANDOM" for example..?
antto
by futureanalogue on Sun Mar 24, 2013 5:43 pm
I used conbox...i had tried it with control and it could not find it...
when i turn it on now every led is lighting up...as if its frozen
futureanalogue
by antto on Sun Mar 24, 2013 6:23 pm
try to flash it again then, the bootloader may still be alive
antto
by futureanalogue on Sun Mar 24, 2013 6:41 pm
nah....it cant connect to the x0x
error: could not get Deviceid string
futureanalogue
by antto on Sun Mar 24, 2013 7:17 pm
check for correct baudrate (in the app settings) and give it a few more tries
if it doesn't change.. then probably the bootloader is corrupted
antto
by futureanalogue on Sat Jun 15, 2013 3:16 pm
i finally got a replacement bootloader from wilzyx...it boots up properly now but there is no sound...!!!! :(
futureanalogue
