coming soon... TR-8060 Analogue Drumsynth
Re: coming soon... TR-8060 Analogue Drumsynth
by substyler on Thu Apr 11, 2013 11:30 am
good point... if I have enough time I'll do a mouser/digikey/reichelt BOM.
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
by decoder23 on Thu Apr 11, 2013 7:59 pm
wow, great news :D i'd like to take a kit too :mrgreen:
decoder23
by substyler on Fri Apr 12, 2013 2:41 am
decoder23 wrote:wow, great news :D i'd like to take a kit too :mrgreen:
yes sir :mrgreen:
substyler
by Paradigm X on Fri Apr 12, 2013 4:21 am
:D
Yay! Im so pleased with this, been wondering how best to get some 808/606 clones together.
Def up for one or two kits (if im allowed).
many thanks , regards
Ben
Paradigm X
by substyler on Fri Apr 12, 2013 4:37 am
Paradigm X wrote::D Def up for one or two kits (if im allowed).
or three... :mrgreen:
but I think I'll limit these kits to 40 or 50pcs. I'm not sure yet.
substyler
by kroutshev on Fri Apr 12, 2013 10:14 am
Hi Man,
great news, i will check that post with many interest :-)
Good stuff !
K.
kroutshev
by Paradigm X on Sun Apr 14, 2013 9:55 am
Hey man
Do you have a ball park cost for the kit in mind? And a very rough idea of when? Just so I can try to plan finances.
You can pm me if youd prefer.
Looks really cool man. How many instruments (or more specifically audio outputs) are there in total?
Ive got a dead old mixer which would make a great enclousre for this pls a midibox sequencer.
Awesome, thanks, Ben
Paradigm X
by substyler on Sun Apr 14, 2013 3:45 pm
I think this kits will cost about 50 - 55 euro plus shipping. it's just the PCB and a bunch of rare ICs and transistors.
you can build your machine with individual outputs plus master out or just with the master output. if you want individual outs for all instruments you'll need 12 mono jacks (plus 2x mono jack for master out)
the enclosure can be made from anything... wood, metal, plastic (maybe an old C64 case?) and you can do your own design on the frontplate.
my own enclosure will be made from aluminum (just like the alu-x0xb0x case)
a frontplate could probably look like this:
I think in about 3-4 weeks I should have everything together.
cheers,
Sub
substyler
by Paradigm X on Mon Apr 15, 2013 4:47 am
Wow, thanks man. Thats excellent news, and a greta price, thanks!
Thanks for the mockup panel too, perfect, gives a really clear indication of what it does. 51 pots and 13 switches :shock:
Im stoked. I was well up for the midibox808 project, but that went pear shaped.
Thanks so much for doing this.
Cheers
Ben
Paradigm X
by barcode on Mon Apr 15, 2013 10:03 am
Hopefully I'm not premature on this one..... but do you have the dimensions of the PCB and placement of mounting holes?
barcode
by altitude on Mon Apr 15, 2013 10:44 am
so is this a pcb with the pots on it or pots mounted to the panel and wired to pcb?
altitude
by substyler on Mon Apr 15, 2013 12:38 pm
the PCB is 300mm x 160mm and the pots are not on the board. pots on the board was my first thought, but I was unable to find all values :?
so every pot must be mounted to the frontplate and wired to the board. all the extra pots (extra filter, extra decay, extra tuning an so on) are optional, if you want the original sound from the 808 you can drop the amount of pots to just 20pcs.
later I'll supply the EAGLE file for download, but I'll wait for the PCBs first to see if everything is perfect.
substyler
by Jaman on Mon Apr 15, 2013 4:15 pm
This looks great and I'm definitely up for a kit.
I have a MIDIbox Seq4 with trigger outs and this could be the perfect companion.
Will keep an eye on this thread.
Top job!
Jaman
by flipp on Wed Apr 24, 2013 4:57 am
Hi SubStyler, hi everyone! Amazing work!! I'm in for at least one :)
flipp
by nilsomat on Wed Apr 24, 2013 7:21 am
Hi Substyler,
great work! I would be in for a kit, too. Frontplate would also be nice, if you plan to produce them in numbers.
Would it by any chance be possible to add the DR-110 Clap to the board, or to replace the original clap in any way?
Thanks a lot!
Nils
nilsomat
