tr 606 confused machine mod guidance needed !!!
x0x0x0x0x0x
rqckmounted
Post by rqckmounted »
hello Adafruit people
I am currently modding my tr 606 ( confused machine mod )
I have 2 a questions for the bassdrum mod
question no 1
on the confused machine site it says:
3. Remove Resistor "R56" and replace with a "470k" resistor. Now solder a wire between "R56" (the side the connects with "C16"), going to the point on the circuit board between Capacitor "C23" and "C24" (where they both meet).
Do I need to scratch to pcb a bit ( remove the green) and make a solder point in the middle of the line.?
or can I simply solder R56 the C23 or C24 ( since they are connected together)
question no 2
9. Now you need to solder another "10k" resistor between "Pin 3" of IC5 and the positive 15V+ power supply. The easiest place to find the 15v+ is at "Pin 8" of IC5.
So Will it be ok if I simply solder the resistor between Pin 3 and Pin 8 of the IC.
On this post picture ( picture 23 ) I do not see a solder resistor on the pcb
Did I missed something here?
Cheers
hope this make sense
best regards
rqckmounted
Re: tr 606 confused machine mod guidance needed !!!
Here's the link if someone want to help:
http://www.confusedmachines.com/mods/BDmods.html
x-11
Post by x-11 »
Hi rqckmounted,
question 1:
Yes solder it to the connection where the both caps meet.
question 2:
Yes try to make it a fast solder (to protect the ic)
peace:)
Return to “General x0xing”
