Hey guys. I'm going to copy/paste this from another message board since I typed it out pretty well and it's long, but my problem is that the x0x won't receive MIDI data at all.
I have two audio interfaces hooked up via USB to FL (Scarlet2i2 and NI Audio 8 DJ). The Scarlet I use for my audio, and the NI Audio 8 has a MIDI channel on it. I have FL giving the Audio 8 DJ MIDI data on Port 1 using the MIDI Out plugin, which is set to Channel 1 and Port 1. When I look at the data indicator on the Audio 8 DJ, it shows that data is indeed coming from FL, and to the pattern of the MIDI I wrote in on the MIDI Out channel. I then have a MIDI cable going from Audio 8's MIDI Out to the x0x's MIDI In. The x0x is set to the MIDI Play mode, and the pattern lights indicate I'm on Port 1 (Light 1 is lit). The audio from the x0x is then sent to my Scarlet, which is in turn hooked up to my monitors. Audio works fine, as tested when I put it into Random mode.
So what's going on? I checked under options and all the MIDI options are checked. The Audio 8 is sending MIDI clock data via master sync, which is enabled. Any ideas?
FL Studio MIDI help
- rv0
Re: FL Studio MIDI help
If you just wanna sync it, it should not be in midi play mode, try pattern play (midi sync)usamablackbelt wrote: The x0x is set to the MIDI Play mode,
Right, but neither of the options work. It appears the x0x just isn't receiving MIDI data.
