hi there, I´m new on this forum. Got my xoxbox a few weeks ago from xoxshop.
I´m in Love with music, but often in enemy with this technics.
So I can´t do it, to connect the Xox with my Computer. Maybe you can help ?
I have Mac Osx 10.6, Ableton Live 8.2, Audio Card FW 410
I connected the Xoxbox with USB to the Mac,"Midi out" from the Box to "Midi in" on the Audio Card.
Then I connected "Mix out" from the Xox with "Line input" from the Audio Card (1x stereo 6,3; 2x mono 6,3 cable)
I can see Ableton Live acting when I play a note on the xox. But the color of this "amplitude" is yellow
When I add an "external instrument" in the midi track, and I set the "midi out" to FW 410 - Ableton is crashing (if I play some notes on xox)
The "Mode select" from the box is on "Keyboard"
If I connect headphones with the xox I can hear the sounds playing
Thanks a lot!
Connect xox with ableton, mac
- mmm
Re: Connect xox with ableton, mac
let me sort this out for you:
For the audio signals you need to adjust levels (naturally) on your Audio card.
If Ableton is crashing when selecting the FW410 output this is unrelated to the other issues. Might be a driver problem.
This probably won't do any harm but also not any good for your setup. USB is only useful for updating the firmware (and possibly storing and editing patterns using a special software); but for the functionality with Ableton it serves no purpose at all.SengsenTrance wrote: I have Mac Osx 10.6, Ableton Live 8.2, Audio Card FW 410
So far, so good. This should enable you to "play" from the xoxbox into Ableton. It will also allow you to sync Ableton to the xoxbox - the xoxbox will be the master then and Ableton the slave.SengsenTrance wrote: "Midi out" from the Box to "Midi in" on the Audio Card.
This will alow you to record the audio output of the xoxbox into Ableton.SengsenTrance wrote: Then I connected "Mix out" from the Xox with "Line input" from the Audio Card (1x stereo 6,3; 2x mono 6,3 cable)
The color of which amplitude? Audio or MIDI?SengsenTrance wrote: I can see Ableton Live acting when I play a note on the xox. But the color of this "amplitude" is yellow
Now this sounds as if you want to "play" the xoxbox via MIDI from Ableton. In this case you need an additional connection from the FW410's MIDI Out to the xoxbox MIDI In. If you want to really "play" it (as in having clips with MIDI data that should be played back from the xoxbox) you need to put the xoxbox in MIDI Play Mode. If you want to use the xoxbox's internal patterns and tracks in sync to Ableton you need to put the xoxbox in the appropriate Mode, too - and you need to enable sending MIDI sync on the FW410 Out.SengsenTrance wrote: When I add an "external instrument" in the midi track, and I set the "midi out" to FW 410 - Ableton is crashing (if I play some notes on xox)
hi and thanks for the reply and sorting out,
that are already some good hints.
I´m just getting the (yellow) amplitude on the "Midi" Track.
No Audio Signal at all
Well I don´t need that (in the moment)
- mmm
Perhaps it's best if you first tell us what you're trying to accomplish with the Ableton-xoxbox combination. Then it will be easier to find out which connections are needed.
