I just installed the latest (i think) SokkOS and i can no longer transpose to the highest octave up (when it starts blinking). Nothing happens when UP is lit and i press it again. Before the update i had patterns with notes in this octave and i could go to that note and see the UP blinking. I then pressed DOWN and it went down as expected (to when the light is lit), but i can't go back up (to when it blinks).
I downloaded the OS from here: http://forums.adafruit.com/viewtopic.php?f=13&t=43270
I tried updating again but no change.
SokkOS 2.0 last Octave Up issue
Re: SokkOS 2.0 last Octave Up issue
Change the setting for that.
The settings menu on User C:
1. 2*UP When lit, prohibit writing of 2*UP notes
2. SAVE TEMPO When lit, tempo will _not_ be written to EEPROM
3. SAVE NEW = CHANGE When lit, pattern change to newly written location
- paland
Sorry, all i understood from that was that it's a setting in User C.... Is there a manual somewhere i've missed where these things are specified?
Edit: Ok i think i figured it out. I "un-lit" the first "note" button in User C and the 2*UP feature is now working. Thank you good sir.
Sorry, i thought i wrote that but obviously my synapses were on some sort of vacation for a moment. :)
You are completely right, the pattern numbers corresponds to the 1,2,3 and setting those settings on/off.
