hi,
i'm unclear on how accurate tuning can get - for example, when looking at my CV, i have a couple pitches that are outside far enough to swing it enough to be problematic - for example, i have 1.009, 2.025 . 2.996, 3.999, 5.006
that c at 2.025 is amost 30cents off the upper octave above as it swings the opposite way in drift. i'm assuming the reason for so much drift is due to differences in the resistor network tolerances?
my cal and power voltages are exact. perhaps i'm missing something? please advise w/ any ideas
thanks
note accuracy question - individual notes out
- antto
Re: note accuracy question - individual notes out
the CV relies on properly calibrated 5.3333333... reference voltage (TM6)
then, it's down to the resistor network
the bom suggests 1% tolerance resistors
you might want to use multi-turn trimpots for TM6, and the VCO pitch tuning (TM4, TM5)
- mmm
Usually the resistor network is to blame for this. 1% tolerance is not sufficient.
Try resistors with 0.1% tolerance for R74 to R90. If I'm reading the schematic correctly the TB-303 also used 0.1% resistors for this network.
- 303.jpg (78.35 KiB) Viewed 1757 times
- altitude
+1 on the 0.1% parts. That's what I used on all my builds
