turned on my 'box today and the sequencer isnt producing note CV's, all are the same note
envs are firing, and CV in transposes, just not the internal sequencer..
any ideas what that could be?
sequencer stopped producing note CV
- antto
Re: sequencer stopped producing note CV
the CV-out (pitch) is outputting the same note? what is the voltage?
is the synth itself playing properly the pitches then?
cv out and xox sound out is the same note
cv in works
i dont have a way to measure the voltage, it was bought ready-made
cv in works
i mean both are stuck on one note
- antto
is everything else working? synth (vco, filter, vca..), sequencer (buttons, leds, patterns) ?
which firmware? the easiest thing you can try is to reflash the firmware
I'll try that when I get home.
Everything else works fine .
Can the firmware sometimes go screwy then? Running marOS
Thanks for all your help antto,it really is appreciated :)
Just flashed to sokkos and back to marOS and still the same problem.
everything else works fine, just the notes. master tune re-tunes the osc, but the sequencer is only sending one note....
any ideas? does it need someone to look at it? i didnt build this myself
- antto
get a multimeter, even a cheap one is better than nothing (mine was 2.5 euro)
what kind of mods does your x0xb0x have, specifically concerning the VCO?
xox/io full mod
- antto
oh... well.. contact brian perhaps
- rv0
Follow the testing procedures in the x0xI0 manual.
Probably a cable came loose somewhere, you bad connection in CV in jack ?
