It seems that the internal tempo of my x0xb0x is something like 120.8 BPM.
Then turning the "TEMPO" knob will change to 119.8, 118.8, 117.8 etc. or 121.8, 122.8, etc.
How to reset BPM to 120.00 ? (I would prefer, without computer!)
Reset BPM tempo
- antto
Re: Reset BPM tempo
you can't
the firmware only increments the tempo in 1BPM steps, thus the tempo is probably 120 when you measure it as 119.8
Re: Reset BPM tempo
I thought that when you use Tap tempo, you could easily go to something like 119.8.
Is it impossible ?
Is the BPM obtained with Tap tempo rounded to the nearest integer ? (ie tap tempo 119.8 => 120)
Is it impossible ?
- antto
Re: Reset BPM tempo
no, not "impossible" ... just not doable with the stock firmware
Re: Reset BPM tempo
ok so just to be sure : the stock firmware always use integer BPM ?
(even when using Tap tempo ?)
- antto
Re: Reset BPM tempo
yes
n0nx0x2 does too, but it has a tempo calibration feature which lets you get closer to "120"
it's still not "perfect" tho
- bobnintendo
Re: Reset BPM tempo
i noticed my x0x's "120 bpm" is actually exactly 120.24 bpm... i'm new to this whole analogue business so maybe that's normal but still a little annoying
