How to use x0xb0x as a midi to din sync converter?
by intellijel on Thu Jul 24, 2008 12:27 pm
I use ableton as my main sequencer. How can I use my x0xbox so it receives midi from the sequencer and then sends out dinsync so an MC-202 attached to it will play?
When I use the x0xb0x in standalone pattern play (with dinsync out) it works, I just can't figure out how to do it without playing patterns.
Any tips?
intellijel
Re: How to use x0xb0x as a midi to din sync converter?
by mome rath on Thu Jul 24, 2008 12:40 pm
intellijel wrote:I use ableton as my main sequencer. How can I use my x0xbox so it receives midi from the sequencer and then sends out dinsync so an MC-202 attached to it will play?
Any tips?
cv/gate :wink:
mome rath
by phono on Thu Jul 24, 2008 1:09 pm
Any tips?
cv/gate :wink:
not with the mc202, unless you like lagged weird quantised notes (the 202 needs modding for this to work well)
but anyway back to the op's question. The quick fix is to use it as you say but with a blank pattern of 16 steps
If you set it to midi play and a blank pattern it might still send out din, i dotn know actually.
But it would definately work in pattern (sync out) mode, if you made a blank pattern. The x0x would be the master clock here of course.
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
by futureman on Sat Jul 26, 2008 9:35 pm
It's actually pretty easy to mod the MC-202 and install extra cv & tage in's which bypass the CPU to get rid of that crappy lag. if you built your xoxbox, you should def be up for this.
I've done this on quite a few MC-202's and it works wonders.
look here for semi instructions on how to do it.
(FYI Dinsync is only sync, not any note info..)
http://www.cykong.com/Synths/Roland%20M ... -Mods1.htm
This website also notes how to add extra cv's etc, which you could do if you wish, but my advice would be CV, Gate and filter is you want.
Regards
Mike
futureman
by Computer Controlled on Sun Jul 27, 2008 12:41 am
The x0xb0x automatically converts MIDI sync to DIN sync, there's nothing you need to do.
Synths: SH-1 . SH-101 . TB-303 . JX-3P . x0xb0x . uWave II . Alesis Ion . Pro-One w/Synthwood case . MoPho . Monotron
Drum Machines: TR-707 . R-70 . E-MU Procussion
Computer Controlled
by octelcogopod on Wed Aug 06, 2008 6:38 am
Computer Controlled is right -- the x0xb0x outputs DINSYNC pretty much all the time, even when it's slaved to another midi source (you can set it to a blank pattern and simply use it as a MIDI-DINSYNC converter)
octelcogopod
by Mike Oxford on Thu Jul 19, 2012 11:00 pm
hi,
I'm having the same issue..
I want to use Logic's sequencer to send Midi NOTE ON/OFF to Xoxbox and need the Xoxbox to send clock to TR606 via Dinsync...
somehow when I use the "Midi play" mode, the sequence from Logic gets played well on Xoxbox, but Xoxbox does not send Dinsync clock to TR606 :(
If I try other modes like "Pattern MIDI Sync", Xoxbox sends Dinsync Clock to TR606, but does not play my sequence from Logic.
Any ideas?
Thanks.
Mike Oxford
by antto on Fri Jul 20, 2012 8:13 am
yes, read my other reply, and use the x0x's internal sequencer
or get yourself a midi-to-dinsync converter
antto
