Hi, I am a x0xb0x noob and have some questions about midi/sound delay.
I have like 35ms delay on midi out (patt midi out) to ableton from x0xb0x. I have tried buffersize, driver error compensation, hardware latency but still the sound/midi from x0xb0x does not sync with ableton. Also, when recording midinotes to ableton i can see that it laggs when adding notes.
I have now checked ”track delay” field to put out a -35ms on external instrument (x0xb0x) but it doesn't help. Only thing that works is if i add ”track delay” to all channels (other then external input) to +35ms.
Is there any other workaround or fix for the delay? It really sucks to add delay to everything but external instrument (x0xb0x)
Do you all have delay/latency with x0xbox?
Appreciate all help!
//Jon
(FYI i use macbook with internal soundboard + midi-usb adapter)
x0xb0x delay/latency in ableton *fixed*
- Jonspion
- Jonspion
Re: x0xb0x delay/latency
*Fixed*
I found the fix in Ableton.
In Options > MIDI sync > expand port and choose > MIDI clock sync delay. Change parameters to negative value. DONE.
//Jon
//Jon
