I have a Modemachine Xoxbox (version 1). It has recently been playing up, not syncing to other sequencers, not being able to enter edit pattern mode etc. Sometimes when it finally enters into pattern edit, you'll be programming away and it'll suddenly switch back to pattern play mode. I thought I had found the issue, which I thought was the pattern select pot, as I found pushing it down while I twisted it seemed to work, for a while (now it doesn't).
Basically Im good at soldering but have no knowledge of electronics. So before I pull it apart and replace the pot, does that sound like its the sort of problem a dodgy pot would cause?
cheers!
Dodgy Pattern select pot on xox?
