I just want to verify this.
When I am in pattern edit mode:
the next LED lights when I press the button but stays lit when I press the PREV button. the PREV LED never lights.
I checked the soldering and orientation of the LEDs and the controller IC and all is as it should be.
If this is not normal behavior, I need to replace the IC.
Or the firmware has a control error.
Cheers
Previous and Next LED behavior
- maxtim
- chairman meow
source code says...
According to pattern_edit.c, the 'NEXT' LED is lit to indicate that the synth is in step-write mode. This is not mentioned in the user manual. Nothing indicates that the synth is in run-write mode (other than the fact that the 'PREV' button doesn't work... or the 'R/S' LED if you happen to be playing at the moment).
IMHO, the existing run-write mode should be done away with. The step-write mode should allow you to play and stop the pattern if you wish, the existing run-write mode doesn't add any functionality.
I would like an additional mode that started at step 1, allowing you to hit note keys while incrementing the step with each key press, for easily setting up the base of a pattern.
