I finished mine last summerAngryChef wrote:Thanks for the tip!
I think I am covered because the place I got them from had all the values in 7.5mm pitch (unlike larger distributors like Mouser and Digikey) ... Except for those weird little 33pF ones those are 5mm (I'll have to bend them just a little).
What did you use for your 9090? Are you finished?
You can see i used a mix of AVX and Wima caps but there were several pitches used on the PCBs so you may want to look at whats what or you will have to bend leads. I also added a second noise source separate for the clap so you dont get that weird phasing issue when you fire the clap and snare at the same time (bottom pic)
