Powering OLED SSD1306 with external 9V
Postby Makizard » Fri Jun 29, 2012 6:33 am
I am new to the forums and I would be very grateful for any help. I am a novice at electronics and I seek to power the SSD1306 OLED (http://www.adafruit.com/products/326) with a external voltage of 9V through an Arduino UNO. I previously attempted this and burnt out a logic shifter + OLED by foolishly attaching 9V to the logic.
Do I deactivate the charge-pump by attaching Vbat with Vdd. Plug in a AC/DC 9V power source and wire the Arduino UNO Vin to Vcc?
Thank you for any help and/or advice.
Makizard
Re: Powering OLED SSD1306 with external 9V
Postby adafruit » Fri Jun 29, 2012 1:45 pm
we dont suggest it - the built in booster works great and is pretty efficient!
Postby Makizard » Sat Jun 30, 2012 6:10 am
Hello Adafruit,
Thank you for the advice. However, I want to make the screen as bright as possible. Is there a way to achieve this?
Makizard
Postby adafruit_support_bill » Sat Jun 30, 2012 6:34 am
bright as possible for how long? Over-driving a display will dramatically shorten its lifetime. The built-in circuitry keeps the display current at an optimum safe level.
The manufacturer recommends a resistor change if supplying 9v directly to VCC. The details are in the user's guide.
http://www.adafruit.com/datasheets/UG-2864HSWEG01%20user%20guide.pdf
Postby Makizard » Sat Jun 30, 2012 6:48 pm
Hello again,
I wanted to know what is the wiring that I have to do to achieve the 9V to drive the screen. Apparently the project doesn't care much for the life-span of the device. Without replacing the resistor, how would I wire it?
I started with the wiring presented in the adafruit tutorial (http://ladyada.net/products/oled12864/) using USB-power and then wired a 9V battery straight to the VCC. The screen turns off and the OLED heats up significantly (to the point of burning). I am obviously doing something wrong.
Sorry for my newbie questions... :)
Thanks again for any and all support ~
Makizard
Postby adafruit_support_bill » Sun Jul 01, 2012 5:03 am
The resistor change is necessary to maintain the current at a safe level.
From pages 4-6 in the controller reference manual:
* R1 should be replaced as 560kΩ while supplying 9V on VCC externally.
IREF:This is segment output current reference pin.
A resistor should be connected between this pin and VSS to maintain the IREF
current at 12.5 uA.
Return to General Project help
Users browsing this forum: No registered users and 6 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
