Transistor Issue
- zener
Re: Transistor Issue
It's called series/parallel, and mstone is right as usual. The Vf of LED's are not all the same. You can put the odds more in you favor by using all the same PN but they will still not all have the same Vf. This is why each LED, or series LED string, needs its own series resistor.
- zener
What he said is when you have the anodes connected directly to the IO pins, then when the pin is high the LED lights. However, when you have a PNP transistor hooked up as you do, then the LED lights up when the pin is low. What this means is you have to invert your output. If your LED value is 255 (full on) then with the transistors, you would need to turn that into 0. Similarly a 0 would need to be 255. In the second code there are lines like this:kculm wrote:I thought he meant I had to set the pins High.
analogWrite( GREEN, 255 - greenVal );
- modeller
Here's what he said-Zener wrote:It's called series/parallel, and mstone is right as usual.
That may be his rule, but it's not a parallel LED circuit: such a circuit does not have one resistor per LED. A parallel LED circuit has all the LEDs in parallel and one resistor. The current is then the number of LEDs * the current of each LED. The fact is that it's possible to wire up LEDs in parallel, and whether or not you approve of it, it's done -[email protected] wrote: For parallel circuits, the rule is "one LED, one resistor".
- zener
A million wrong things can be done. We are just saying it is wrong from an engineering point of view. The Vf's can vary so current will not be shared in that case. Read any application note from any LED manufacturer, that covers LED arrays and they all will tell you the same thing. In my job I have to provide correct solutions that work and will not fail. That design would never pass any design review.modeller wrote:The fact is that it's possible to wire up LEDs in parallel, and whether or not you approve of it, it's done -
- modeller
I also said not to do it didn't I? But the fact is, we are discussing what series and parallel circuits are. Whether it's right or wrong, a parallel LED circuit is wired up the way I showed. If you don't believe it Google it. People also do make it work, even though you and I wouldn't want to do it. If you want to make people understand, you need to show the circuit plainly as it would really be, and one resistor per LED is not a correct representation of a parallel LED circuit. I don't know why you are complaining about what I posted since it's correct.Zener wrote:A million wrong things can be done. We are just saying it is wrong from an engineering point of view. The Vf's can vary so current will not be shared in that case. Read any application note from any LED manufacturer, that covers LED arrays and they all will tell you the same thing. In my job I have to provide correct solutions that work and will not fail. That design would never pass any design review.modeller wrote:The fact is that it's possible to wire up LEDs in parallel, and whether or not you approve of it, it's done -
- adafruit_support_bill
Gentlemen. Keep it civil.
Guys thank you all for your reply's. I did not mean to open up a can of worms. As I said before I am totally Green.
And for me, doing something is the best way to learn. Even if i have to make a few mistakes along the way.
I get a lot out of the posts on this forum. More then any off the book I have read.
So once more...Thanks...
Keith
Keith
Ok guys once more Thanks for all The help. But I need to recap.
As I am rereading the post I see that and please correct me if I am wrong. What I was doing with the RED LEDS would be considered series/parallel Array
That is something that can be done, but is not recommend. And the way I should be doing it (and all of my parallel Arrays) is one resister on each LED.
Am I correct or should I give up on electronics and stick to networking.
Keith
Keith
Ignore the last few posts and go back to this one: http://forums.adafruit.com/viewtopic.ph ... 26#p184338
There are three leds in your diagram that 'share' a resistor. These should each have their own resistor.When you put the LEDs side by side (both cathodes connected to GND), you want a resistor per LED.
When you put the LEDs side by side (both cathodes connected to GND), you want a resistoradafruit_support wrote:Ignore the last few posts and go back to this one: http://forums.adafruit.com/viewtopic.ph ... 26#p184338
Thank you.
Am I correct in assuming that would be the same for common Anode ?
Yes. It doesn't matter whether the resistor is on the anode or cathode side, as long as it is in series with the led.Am I correct in assuming that would be the same for common Anode ?
Would I ever need to do it like this?
If you can't afford the resistors and are 'feeling lucky', you might get away with it. But it is not good practice. Each led should have its own resistor to limit the current.
adafruit_support wrote:If you can't afford the resistors and are 'feeling lucky', you might get away with it. But it is not good practice. Each led should have its own resistor to limit the current.
Thanks Once More.
I think it's embedded now. Don't be Cheep and lazy now, because it will cost me more in time and money latter.
