I am trying, probably fruitlessly, to debug a non-operational wireless thermometer. We have this projection atomic time/temp clock that projects the time and indoor/outdoor temp on our ceiling. We loved it so much we bought 3 of them - as they would fail! (I know, we should have suspected the design.) The indoor clock/temp works fine. But the outdoor temp is very intermittent. When you put in the batteries and press the reset button, the red led will blink and SOMETIMES you will get a few cycles of outdoor temp showing up on the indoor unit. Have tried distance, new batteries, full reset of both units, etc. So bravely I disassembled it and found the attached board. On the back of the board is a small metal can soldered to the board - looks like a crystal case with HR433C on it. (X2 on the board just below the middle coil.) Only 3 (Chinese) hits for the part number on Google but I think this is the 433MHz wireless transmitter.
With my handy-dandy Bus Pirate, I was ready to see what protocol they used to transmit the temperature. So my questions are:
1) where would you begin to troubleshoot this?
2) What the heck is the black round dot in the center of the board. Is that some kind of security cover for an ASIC or something so it can't be reverse engineered?
Thanks for any help. (If I can't get THIS to work, maybe I dump the outdoor unit and switch to an XBee and figure out where to inject the data stream in the indoor unit. But I would still need to figure out the protocol.)
Rick
