Questions on drift and tolerance
Postby SmallWalrus » Wed Feb 29, 2012 12:18 am
Hi guys,
I've been parts shopping for a little project that I'm looking to build, and I got stumped by this. The build requires a very exact matched pair of capacitors giving as close a total capacitance as possible to 1020pf (within 0.5% tolerance).
I noticed that RS has some silver micas that are rated to 1% tolerance for 1000pf which I can then combine it with another small silver mica rated to 0.5% tolerance, and get my 1020pf.
Alternatively, I can grab a LC meter and head down to the nearby electronics shop and cherry pick out some silver micas that are rated at 5% tolerance from their shelf. The store silver micas are much much cheaper.
My big question stems from the concept of tolerance and drift. Is tolerance only relevant for the actual measurement of a component with respect to it's rated value? Or will a component that was originally built to tighter tolerance be less susceptible to drifting as well?
I guess my queries can be summed up as, "Will I score a better deal (and not compromise anything) if I cherry pick out some nice 1000pf caps from the store, as opposed to getting the more pricey ones from RS?" :)
SmallWalrus
Re: Questions on drift and tolerance
Postby adafruit_support_bill » Wed Feb 29, 2012 5:49 am
Two caps based on the same dielectric (silver-mica) should have similar drift characteristics. Cherry pick away!
Postby Zener » Wed Feb 29, 2012 12:47 pm
I don't know what you are doing but I would guess the match is more important than the 1020 value. But without the schematic it is hard to say for sure. Usually when something is actually built you may find the exact values are not so critical, or may need to be changed a bit. But matched values, where needed, are always critical.
Zener
Return to General Project help
Users browsing this forum: Google [Bot] and 4 guests
New Products [103]
LEDs[109]
Cables[61]
