I'm using a arduino to control multiple (9) motors. Is it possible to use one snubber diode in parallel with all the motors connected to the positive of the motor and the emitter of the transistors? I have attached part of my schematic which shows using individual diodes in pencil and the proposed single diode in red.
Thank you.
Use One Snubber Diode on Multiple Loads
- Screen Shot 2012-03-04 at 1.26.14 PM.png (246.27 KiB) Viewed 782 times
- john444
Re: Use One Snubber Diode on Multiple Loads
Sorry jamilm9. But the purpose of the diodes across the motors is to absorb the energy in the motor's magnetic field when current to it is interrupted. With only one diode, where you indicated on the schematic, each drive transistor will be subjected to the 'kick-back' from its motor. Diodes are inexpensive and they reduce the chances of blowing the transistors. Also, it is better to catch it at the source so connect each diode as close to the motor as is reasonable. Looks like an interesting project. Good Luck
- easternstargeek
John444 is right, but you can still simplify things while saving space and money, too!
You don't say how big the motors are, but have you considered using a Darlington transistor array to drive them? The ULN2004A, for example, can control 7 channels at up to 500mA each, and there are built-in snubber diodes which would be perfect for your motors. Like your circuit, that chip uses low-side (NPN) drivers.
http://search.digikey.com/us/en/product ... -ND/599602
http://www.st.com/internet/com/TECHNICA ... 001244.pdf
An 8-channel version is the ULN2803, also with snubber diodes:
http://www.ti.com/lit/ds/symlink/uln2803a.pdf
If you ever need high-side drivers, consider the Allegro UDN2981, which gives you 8 PNP Darlingtons (and a snubber for each):
https://www.jameco.com/webapp/wcs/store ... Id=1762681
Each channel is good for up to 350mA, and your motor voltage supply can be anywhere from 5 to 50 volts.
For even more fun, you can use this chip:
https://www.jameco.com/webapp/wcs/store ... tId=241875
It is a single-channel full H-Bridge that can drive a DC brush motor in either direction up to 1.6A!
Have fun, and do come back to tell us what you are building.
Good luck!
Good luck!
- philba
Yeah, that proposed diode won't do anything at all, assuming it connects voltage source to ground. The collapsing field current would punch through your transistors.
The uln2803 is particularly nice because it has all the resistors you need as well. sweet package.
Phil
Phil
